Question about ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ)
Asus a7n8x deluxe
Puter worked fine with 2 wd raptor drives in raid config. I took them out and put in idd drive and loaded windows xp on it and then I put in a new maxtor 160gb drive and now the bios does'nt detect any hard drive. It detects the floppy and cd only. I also tried a new 800w ps but no change. I tried ASUS but never got a reply. Thanks for any help. Jim
  • 167 Answers
Please make sure your HDD are in proper configuration. An IDE device have two cofigurations. Master and slave. Any motherboard will have two IDEs. Primary and Secondary. You can connect two drives to one IDE in Master and slave configuration. This is determined by setting a small pin called jumper setting. You should visit the following website to know more about setting jumper for a Hard disk. This way you could solve your problem.
Posted on Sep 27, 2007
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) When I built my PC in '05 I installed 4 HDD's on the A7N8X-E Deluxe. Now my main drive is failing so I've cloned it to a new HDD, but...
hi Memory,
You can try 2 things:
1. If the HDD has jumpers make sure to set the one you want to boot from as the master.
2. Go into your BIOS and choose which device to boot from first.
Also just to be sure disable all other drives and boot with the single drive to ensure that it actually works. There are bootdisks that can help with booting issues one being called ultimate boot cd but i wouldn't touch settings unless you know what your doing.
Hope this helps,
Jan 31, 2011 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
Sata/bios problem???
Each non-SATA drive (CD or DVD or disk-drive) will have a small grid of pins, usually 3-by-2 or 4-by-2.
Look very closely, for labels: MA(ster), SL(ave), C(able)S(elect) for each pair of pins.
You allowed to have a maximum of *TWO* drives as "master",
but you probably have *THREE*.
Move the small "jumper" on each drive to the 'CS' position.
Then, the proper "master/slave" relationship on each IDE channel will be established.
Make sure your "boot" drive is connected to the "end" (not the "middle") connector on the "IDE1" (not "IDE2") channel.
Nov 06, 2009 | Computers & Internet
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
A7N8X-E Deluxe Nforce2 will not POST
I had the same issue a while back. You need to reinstall windows on the new PC. Your motherboard is expecting to see a certain hard drive that has the windows boot sector on it. If it doesn't see that exact hard drive the computer will never boot... so quick fix, just reinstall windows and everything should work fine.
Jan 04, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
vista wont load on more than 2 GB of RAM.
Reduce it to 2 GB and then install vista.
after complete installation add the pther RAM.
Jan 10, 2008 | Computers & Internet
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) Logo
96 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
