Question about Citizen Eco-Drive Calibre 5700 AT1070-54L Wrist Watch
Citizen Eco-Drive H570: How do you sync the time and the 24 hour hand?
  • 161 Answers
SOURCE: Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Posted on Nov 02, 2008
dmbgo
  • 58 Answers
SOURCE: the hour hand is not matching up with the digital time
Hi this means that the hour hand has slipped on its shaft, the watch needs to be taken apart and the hand removed and retightened and then reset in the correct position. It was probably caused by a sharp knock
You will need to go to a watchmaker for this
Cheers
Dave
Posted on Jun 22, 2009
SOURCE: My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Oct 01, 2009
  • 93 Answers
SOURCE: I own a Citizen Eco Drive Calibre 8700 Blue dial
If your watch was not stored where it could have light shining on it the LI battery would drain completely. There is a possible solution although it does not work all the time. It depends on how badly the battery has been allowed to drain.
Setup a lamp that will shine on a counter 24 hours a day and set your watch there. It helps if the lamp is about 1.5 - 2 feet above the watch. A 60 watt incand. lamp will work fine.
Leave your watch under this lamp for 3 - 4 days 24 hours a day. This will supply the solar cells with enough energy to recharge the battery and get it working again. If after this time it is still not working then the battery is just not going to accept a charge again or there is something else wrong that a watchmaker is going to have to fix for you.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 03, 2009
  • 101 Answers
SOURCE: Describe your Citizen Skyhawk Eco-Drive
Here is how to correct the 0 Position for your watch.
While your the crown of your watch is down in the starting position , turn the crown until the mode hand (this is the circle at the bottom of the face) reaches CHR
At this time now pull out the crown until it clicks two times, two the second setting of the crown.
This will bring the watch to the 0 position correction function.
you can turn the crown clock wise to correct the hour hand.
press the a button to switch hand to second, or press again to switch to minute. Then use crown again to correct 0 position.
The hour and the 24 hour hand is in conjunction with each other.
then push down the crown all the way in and you should be all set.
Posted on Oct 19, 2010
Testimonial: "Thanks much, that's great help, solution proposed totally worked. I have this watch for about 8 years now and never once able to fix this 0 correction"
How do I manually set my Eco-drive wr200
Pull crown out 1 click to set day/date, set to one day behind actual date... Then, pull crown out an additional click to move hour/minute hands around to set exact date by hour/minute a complete 12-24 hour revolution if necessary to get AM or PM accurate for the proper day/date. :)
Jul 05, 2014 | Citizen BL5314 52E WR200 Eco-Drive scyba...
I have a Citizen eco-drive blue angel watch and the hands are out of sync with the digital clock. Can you help?
Hi there. Your hands are driven by the digital. Please consider reviewing the instructions for setting at: http://www.citizenwatch.com/
If there is in fact a fault, please consider returning the watch to citizen for repair and adjustment.
Jul 28, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Can set time on watch eco drive
Here is a simple steps to set up the time:
Pull the crown out one notch
Turn the crown to align the mode hand at the time mode Time
Pull the crown out another notch
Turn the crown to set the 24 hour hand, hour hand and minute hand to the current time.
Return the crown to the normal position in synchronization with a telephone time signal or other time service.
For full instruction and visual about your watch kindly click on the link.
I hope this will help you resolve your issue.
thank you for choosing Fixya
Mar 05, 2011 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Describe your Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Problem: How to correct 0 position of 24 four hour hand. I think its done in conjunction with hour hand but how?
Oct 18, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Utc Dial does not match Digital utc readout and I can't for the life of me figure out how to sync them
I finally figured this out... You must zero all the hands by setting the mode to CHR and pulling the stem to the second stop. Go through the process of setting the hour and second hand to zero. The secret is that zeroing the MINUTE hand also controls the UTC display zeroing. You will have to crank it until the UTC display reads 0:00 (24:00). Then go back and set the time and so on as usual.
May 11, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I own a Citizen Eco Drive Calibre 8700 Blue dial Romen letters. I have not used it for very long time (6 months). Now when exposed to light only the second hand works but the minute hand and hour hand do...
Hope this helps.
Ken
Nov 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
hope this help
from
Chicago, IL 60601
Ph: 312 641 7000
Oct 01, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
The hour hand is not matching up with the digital time
Cheers
Dave
Jun 21, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Eco-Drive Calibre 5700 AT1070-54L Wrist Watch Logo
26 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
