Question about Citizen Eco-Drive Calibre 5700 AT1070-54L Wrist Watch
Citizen Eco-Drive H570: The 24hr hand is 4 hours behind the actual time shown on watch. How do I reset the 24hr hand?
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
escapement
  • 2334 Answers
SOURCE: Citizen Eco-Drive Skyhawk JR 3060-59F
Paste this link into your browser and follow instructions:
http://www.citizenwatch.com/CUK/English/settings_int.asp?caliber=C650&interactive=C650
If this is not the correct caliber number, click on technical support tab in the same webpage and find the right one for your watch.
DO NOT FORGET TO RATE, PLEASE.
Posted on Mar 09, 2009
SOURCE: second does not reset to 12
You should be able to solve this by pulling out the Crown(the one with which you set your normal clock), Pull it out in the 2nd stand.
Then by pushing the 'start/stop' button --> you change the minutes.
By pushing the 'lap/reset' button --> you change the seconds
It worked for me, took me a few minutes to figure it out, i hope this saves others the time of doing that :p
Posted on May 26, 2009
  • 23 Answers
SOURCE: Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Posted on Jun 25, 2009
escapement
  • 2334 Answers
SOURCE: Citizen Eco-Drive Blue Angel Watch C650.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all citizen watch manuals. Rate me, please.
Posted on Mar 03, 2010
How do I manually set my Eco-drive wr200
Pull crown out 1 click to set day/date, set to one day behind actual date... Then, pull crown out an additional click to move hour/minute hands around to set exact date by hour/minute a complete 12-24 hour revolution if necessary to get AM or PM accurate for the proper day/date. :)
Jul 05, 2014 | Citizen BL5314 52E WR200 Eco-Drive scyba...
My Citizen Skyhawk analog UTC hour hand is alway 1 hour ahead of the UTC digital hour. I've tried reset and the hour/min hand alignment process without success. Any ideas other than sending in the watch...
You've gotta go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) or ON (for summer time). According to their website FAQ, they can't determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. Disappointing, I know. I just spent half an hour going through their website looking for some master switchover as well.
Mar 27, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
The date on my Citizen JR3090 watch changes at midday instead of midnight how do if fix this
Reset the time by 12 hours. Just wind the hands to the right time but only go around once not twice. So for example it's 5 pm now. Wind the hands around again to go to 5 again. It should do the trick.
Jan 30, 2011 | Citizen Skyhawk Eco-Drive JR3090-58L Wrist...
Describe your Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Problem: How to correct 0 position of 24 four hour hand. I think its done in conjunction with hour hand but how?
Here is how to correct the 0 Position for your watch.
While your the crown of your watch is down in the starting position , turn the crown until the mode hand (this is the circle at the bottom of the face) reaches CHR
At this time now pull out the crown until it clicks two times, two the second setting of the crown.
This will bring the watch to the 0 position correction function.
you can turn the crown clock wise to correct the hour hand.
press the a button to switch hand to second, or press again to switch to minute. Then use crown again to correct 0 position.
The hour and the 24 hour hand is in conjunction with each other.
then push down the crown all the way in and you should be all set.
Oct 18, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Hands do not show same time as digital display. the hands are two hours and several seconds behind the digital display. the digital display is correct. when I press the A and B buttons simultaneously...
I have a Casio which had a similar problem and had to resort to reading he instructions to align the times!
I presume that instructions for your watch are not to hand but you can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Mar 20, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Citizen Eco-Drive Blue Angel Watch C650. I can't get the analog to match the digital. i have reset everything to the O positon. Reset time, calendar.
Mar 02, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Oct 01, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
The hour hand is not matching up with the digital time
Hi this means that the hour hand has slipped on its shaft, the watch needs to be taken apart and the hand removed and retightened and then reset in the correct position. It was probably caused by a sharp knock
You will need to go to a watchmaker for this
Cheers
Dave
Jun 21, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
My Eco-Drive watch is 8 minutes fast.
Take it to your citizen dealer. There is probably a problem with the actual movement of the watch and unless you know how to take the watch apart and diagnose the movement then you would not be able to figure it out.
Jan 02, 2009 | Citizen Eco-Drive Silhouette EW869452D...
Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Aug 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Citizen Eco-Drive Calibre 5700 AT1070-54L Wrist Watch Logo
41 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
