Question about play-asia.com
Delete account play asia
Cannot seem to locate a button or method to delete my play asia account. cheers.
I lost my kindle in July, 2015. I have not ordered any books for the reader. What do I do now. I think someone has been ordering on my account.
Navigate to amazon.com on a computer. Immediately access Your Account and navigate to "Manage your Content and Devices." Under Devices locate your lost Kindle and deregister it.
As a precaution you should also visit your account settings and delete your credit card(s) on file. Leave them deleted for a day or two and then return to devices to be sure that the lost Kindle is no longer listed. If it is still listed or in any way visible, then you should call Amazon. (Amazon's software is quirky; sometimes they won't take down a device that you deregister no matter how you try. In this case you must call them. Be warned: calling Amazon is also a nightmare. Be sure you have at least an hour or two to waste, beginning with a conversation with some ignorant tech assistant located in Asia or the middle east.)
Jan 24, 2016 | Amazon Kindle
Tip
TCL LED28T3520 service mode
Overview
MS306C/D chassis is designed for Asia Pacific/South America market. Both Full HD panel and HD panel can be compatible. The signal sources include TV,AV,YPBPR/YCBCR,VGA,HDMI and USB. For YPBPR,HDMI source ,Format up to 1080p can be supported; USB support image, audio and video(up to H.264)playing; The whole process of alignment includes ADC calibration and White Balance adjustments.
Factory Menu 1
Methods of Entering Method 1:Using the remote ,enter the "Picture" submenu in the OSD;
choosing the "contrast" item and press the 9,7,3 and 5 in series,
Factory Menu will appear in the left top of screen
Method 2
Press RETURN button when FACTORY HOTKEY is enabled (ON).
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on May 02, 2015 | Miscellaneous
Remove email that is old on my iphone
The iPhone 4 allows you to choose to remove old messages after one day, one week or one month automatically without you having to do anything.
You must first have to activate this feature for it to work though, otherwise the default is set to Never.
Here's how:
1. Press the Home button.
2. Then select Settings.
3. Next pick General.
4. Now select Mail, Contacts, Calendars.
5. Then choose a desire account you would like to activate the setting.
6. Now tap on Advanced.
7. Select Remove.
8. Finally select a desire period before old email is removed.
Here are your options:
- Never
- One day
- One week
- One month
Once the email is removed from you iPhone you will no longer get access to it again.
Feb 01, 2014 | Computers & Internet
I am sorry, but I am 73 years old and not terribly computer savy, I cannot contack picnik in order to cancell my account since they seem to be the hardest people on the net to contack direct by phone or...
Hi! You can actually cancel your account online. Here's how to:
Delete your Account Share Comment You can delete your Picnik account at any time. By doing so, you'll permanently lose access to your account and all photos in your History. When you delete your Picnik account, Picnik will sign you out and close any image you currently have open.
Registered free users
  1. Sign in at http://www.picnik.com/
  2. On the Home tab, click My Account.
  3. Scroll to the bottom of the page and click the large gray Delete my Picnik Account button.
  4. Confirm Delete Account.
Picnik Premium users
  3. Cancel your current Picnik Premium Membership. If you cancel within the first 30 days of your membership (or 48 hours for monthly memberships), you can move onto the next steps. If it's beyond this time period, you can turn off auto-renewal and then complete the next steps when your plan expires.
  4. Refresh the My Account page.
  5. Scroll to the bottom of the page and click the large gray Delete my Picnik Account button.
  6. Confirm Delete Account.
Hope this helps! Have a great day. :)
Jun 29, 2011 | picnik.com
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
How do I empty my Iphone mailbox
Doesn't matter which folder you're in, it works the same - just hit "Edit" at the top - all of the emails scoot to the right revealing a faint circle. Tap the circle next to the message you want to delete and it'll turn red. There will then be a button at the botton that says "Delete" with the number of msgs you've selected in parentheses.
If you want to totally empty every message, you'll have to select each one and then delete them, but in the trash folder there will be a button that says "Delete All" at the bottom after you hit "Edit"
Sep 24, 2010 | Apple iPhone 3G
Region code usa will not play in my dvd player on my laptop it is a toshiba satellite laptop i cannot find where to change the region code
To change your Region Code click Start- Computer - right click DVD Drive - Properties - Hardware Tab - Click on the DVD Drive on the list of hardware then click on Properties button - click on DVD Region Tab - choose your country then click ok button - click apply button then ok on the previous window - restart computer.
Note: Region Codes can only be change up to 5 times.
Here's the list of Region codes and its respective countries.
Region code and Area
0 Informal term meaning "worldwide". Region 0 is not an official setting; discs that bear the region 0 symbol either have no flag set or have region 1–6 flags set.
1 United States, U.S. territories, Canada, Bermuda
2 Europe (except Russia, Ukraine, and Belarus), Middle East, Egypt, Japan, South Africa, Swaziland, Lesotho, French overseas territories, Greenland
3 Southeast Asia, South Korea, Republic of China (Taiwan), Hong Kong, Macau
4 Mexico, Central and South America, Caribbean, Australia, New Zealand, Oceania
5 Ukraine, Belarus, Russia, Africa (except Egypt, South Africa, Swaziland, Lesotho, and French overseas territories), Central and South Asia, Mongolia, North Korea
6 People's Republic of China, Hong Kong
7 Reserved for future use (found in use on protected screener copies of MPAA-related DVDs and "media copies" of pre-releases in Asia)
8 International venues such as aircraft, cruise ships, etc.
ALL Region ALL discs have all 8 flags set, allowing the disc to be played in any locale on any player.
Should you have any questions just please leave a comment.
Cheers~
Jul 05, 2010 | Computers & Internet
Yahoo mail is not loading and it says that there is 324 rerroe and sometimes WEBAPAGE IS NOT DISPLAYED even if i tried to search jobstreet.com but other websites were loading fast
Are you using Google Chrome in accessing your Yahoo! Mail account? Are you also playing MW (Mafia Wars) in FB (Facebook)? Eventually, other web sites will load fast because the internet browser that you are using still remembers the cache for those web sites.
If you are not playing MW, you may try to clear the cookies and cache of your browser. Here's how:
Click on the "Tools" menu and select "Options".
Click the "Under the Bonnet" tab, locate the "Privacy" section and click the "Clear browsing data" button.
Select "Delete cookies and other site data" to delete all cookies from the list (alternatively, you can remove all cookies created within a specific time period by selecting the period you want from the dropdown list).
Select "Clear browsing history" to delete traces of which websites you've visited.
Select "Clear download history" to delete records of which files and programs you've downloaded.
Select "Empty the cache" to delete cached website pages.
You can also delete saved passwords (which log you into websites) and saved form data (such as your name and address).
Then click on the "Clear browsing data" button.
Click on the Close button when you've finished.
HOWEVER, if you are playing MW, you are in some short of MW (Mafia Wars) list. Some people are basically wanting to collect more information of the people playing these games. Others who have no problem probably don't mind having these tracking cookies following them.
This 324 ERROR seems to be a problem that occurs in gray area. It's some piece of code between your individual computer and the particular service provider. You may want to contact your computer dealer or the manufacturer to verify this problem. That's the best thing that you can do.
Thank you and good luck!
Jun 17, 2010 | Yahoo Mail
Master reset mac pro
There are a few ways to do this.
Method 1 Create a new user account, making sure to give the user Admin access. Once you create this new user, log into the new user account and delete the old user. This is the quickest and easiest way(this works best with 10.5, if you're running 10.4 or earlier try method 2.)
Method 2 Take the install disc and reboot your computer with the disk in the drive. On start up, hold the "c" button. Now you can re-install the operating so you can have a clean start. (if you don't have the install dvd, refer to Method 3)
Method 3 Delete all the unnecessary applications, once done create a new user with admin privileges. Log in with this account and delete the old account. This way you won't have any of the programs you don't want and the new user will have factory account settings. As close as you can get to a fresh start.
No matter what method you choose, be sure to back up important information.
Jan 26, 2009 | Apple MacBook Pro Laptop Computer with...
play-asia.com Logo
127 people viewed this question
Top play-asia.com Computers & Internet Experts
David Payne
David Payne
Are you a play-asia.com Computer and Internet Expert? Answer questions, earn points and help others
