Turning on we moved in a uhaul across the US. since we plugged in the television it seems to be taking a longer and longer time to come up after turning it on.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
We moved in a uhaul across the US. Moving from one place to another has got nothing to do with tv operation. if it takes more time for light to come then it is a problem in brightness ckt or tube getting weak if tv is old tv. if on the whole more time means cap in power supply might be a problem good luck.
Posted on Sep 27, 2007
SOURCE:
I have a Samsung UF55F9000AFXZA television and about a month ago it started taking a little time turn on and seemed to take longer each time i turned it on. Now it wont come on at all, but it tries. when...
with the fault worsening slowly it points to failing capacitors on the power supply Board which is not uncommon for this brand, there are many repair kits available for this brands power supply boards if you feel you are capable of fitting them try Here:
TV Repair Kits MBTV Electronics
or you could consider replacing the whole panel, a bit more expensive but less technical expertise required, shop Jimmy is the largest supplier of replacement boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 12, 2016 | Samsung Televison & Video
Why does my 1984 chevy c10 silverado slow down going up small hills? I'm moving and pulling a uhaul behind me going back to Texas from Colorado.
An old exhaust converter could be partially blocked
The timing chain & gears could be worn
Egr valve issue
Worn valves that don't seal properly
Trans may be slipping or lock-up in converter is stuck on
Only so much guessing we can do
You have to test things one at a time
Oct 02, 2014 | Cars & Trucks
LG 37LCD2d
Yes it should be taken to local service shop..because its seem that information is not uploading to screen from main board.
Dec 17, 2013 | LG Televison & Video
No longer seems to get any ppower to turn on it was working before it went into the moving van
hi, would help immensely if we knew who built the set and the model number. obviously the move has either un-plugged a connector somewhere inside the set or the move has broken a few solder joints, remove the back cover and with the set un-plugged check for a good connection on all the cables, you`ll have to take boards out to check solder, gl, video-tek
May 31, 2009 | Philips Televison & Video
Tow bar wiring
You need a Trailer Light Power Module - Uhaul, or anywhere that sells hitches and accessories. The module will power the lights directly from the battery - it still hooks into your car's lighting system, but only for sensing purposes, it doesn't put an extra load on the lighting system.
Here's an example from Uhaul:
http://store.uhaul.com/Wiring__lights/Moving/Trailer_Light_Power_Module
Hope this helps :)
Mar 08, 2009 | 2001 BMW 5 Series
Can I move this TV on a trailer?
You would be best moving it on a truck, vs. a trailer. I know that height is a concern, but this damage due to debris can be minimized by judicious use of refrigerator boxes (see local sears store) to protect it.
Either way, plan on having to realign the screen when you finally get it moved. This is normal. Moving on a trailer just might permanently misalign the screen so that the processor in the tv cannot compensate for it.
UHaul also rents blankets / pads without having to rent anything else as well. You might consider that option.
On the other hand, this tv was likely trucked across America inside a trailer on the back of a semi. But that trailer also had a lot more weight in it as well. Personally, I would move it using a pickup.
Dec 21, 2008 | Toshiba 57H81 57" Rear Projection...
Move my 53 inch plasma tv
The best thing to do would be to goto Uhaul and get a box and installation fromthem. Don't dit the set faceing or laying down
Jul 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Horrible picture after moving
Sounds like your convergence chip has gone bad.
Jan 25, 2008 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Ekse
