Question about Boating
I need to know who the axle manufactuer for my sportline triple axle boat trailer
3 Suggested Answers
  • 43 Answers
SOURCE: I know that there are 3 types of boat trailer
Since your boat is fiberglass, you can use either rubber rollers or red soft poly rollers. Aluminum boats can use rubber rollers as well as blue hard poly rollers.
Posted on Oct 16, 2013
  • 124 Answers
SOURCE: I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
Maxim 20'7 boat with a cuddly cabin and a 120 horsepower Mercury force outboard engine. What is the weight of this boat?
if you cannot get the details from the manufacturer of the boat and it is not on the compliance plate that should be attached to the boat( plate shows length, max hp motor to be fitted , registered no of passengers possible ,weight etc ), the only thing left to do is to put it on a trailer that is big enough and have it weighed at a public weigh bridge /station
you will be expecting a weight in excess of 1.5 tons or 1500 kgs
most 20 ft boats run on a tri axle trailer because of the weight and length
Sep 17, 2016 | Boating
How to remove a hub without a cotter pin
The hub has to have a nut holding it on the axle and should have a cotter pin to keep the nut from moving. If you don't see it, it's behind a hub cover or lube cover. You knock the cover off with a rubber hammer, strap wrench, or channel locks (large plyers). Once you have it off the axle you can knock the bearings out of it. Your local auto parts store has a tool they will let you borrow to help with that, otherwise you can use a piece of pipe (of the right diameter), a hammer, and a punch.
May 21, 2014 | Boating
I just bought a new boat and need to buy a boat trailer. Should I buy a boat trailer with the weight capacity of my new boat, or do I need to make sure it can tow more than that just in case?
First of all you should know the height, length, width, and weight of your trailer, which is important and it will make it possible for you to transport your boat. Or if you want you can hire a boat transport services, by taking reference from the Internet or you may ask your friends or relatives if they had ever shipped a boat from transporters, because a boat delivery company had an experience in transporting boats and yacht safely.
Oct 16, 2013 | Boating
I know that there are 3 types of boat trailer rollers, but how do I know which type to use for my boat? My boat is fiberglass by the way.
All I need to know is a 2004 4wd 6cyl vortex 4wd chevy able to pull a 17ft fiberglasboat with 90 horsepwer ob single axle boat and trailer
look up your pulling capacity power of your truck.i had a four wheel drive v-6.ford ranger could not pull my 17 foot v-6 malibu boat. i allways had to ask my friends they had v-8 type trucks no problem.if my friends wanted to enjoy them selfs at the lake and water sky no problem.
Jan 29, 2011 | 2004 Chevrolet S-10
I have a 1977 chrysler 22 sailboat and I am converting a power boat trailer into a sailboat trailer. I'm trying to figure out how far up I need to put the outer supporting boards on the trailer.
I did same reciently for a Nolex 25. Easiest is to measure and copy someone else's trailer.
Would suggest putting boat on the hard , measure the width between mudguards on your trailer ( you want the boards as close to the guards as you can) halve your number , measure same out from centreline of yacht and up to hull from ground. Transpose measurements to trailer.
Hardest part is guessing the correct balance point ( distance from centre of axles to winch) this is so much easier if you have one to copy.
Try to leave everything adjustable in order to tweak once your boat is on the trailer.
Remember the centre rollers need to carry most of the weight, not the boards.
Mar 28, 2010 | Boating
Getting a title for a vehicle
Different states have different laws. In states that charge trailer plates by Weight, you need to pull the Trailer over a scale and show the weight receipt. If the Boat has to stay on the trailer, pull both and subtract the weight of the boat from the total weight. You can find the Boat weight online.
In states that charge a flat fee for Trailer plates, its much simpler. You can also go to a Vehicle Registration center and get a form for the registration. But you need to call ahead to find out if Police or Highway Patrol can verify the Hull# or Trailer ID.
Mar 06, 2010 | Boating
I need to manufacture a boat trailer for a
I have some tips I learned from finding a trailer for my 27 foot cruiser. Really, you can find deals in this economy that make rigging a trailer from scratch too much work.
You need to find the loaded weight of your boat and where the hull needs support from Carver. Your trailer needs to hit the "Chines" correctly, meaning the bunks have to be adjustable to the contours of the hull.
The bunk supports can fit outside, inside, or on top the frame rails Mine started on top of the rails and were converted to the torsion axles, requiring new supports.
The axles need to support enough weight and State laws will say how many axles need brakes. Your choice of electric or hydraulic. The bunks should be made of Cypress, but synthetic decking could be cheaper. Your tires should Load rated D or better and 15 to 16 inch wheels, not 14 inch because of the weight.
There are numerous Boat Salvage yards listed online.
There seems to be a "thing" about the region the boats are used. Some places have orphaned trailers everywhere and others are always married to a trailer.
I have seen Boatyard liquidations with ridiculously cheap trailer prices. Use the internet and look.
Feb 06, 2010 | ShipShape Pontoon Boat Trailer Guide-on...
Boating Logo
458 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
