Question about Eaton 700-016 Hydraulic Hydrostatic Mower Transmission
Broken input shaft - Eaton 700-016 Hydraulic Hydrostatic Mower Transmission
A clutch on 1996 dodge ram 2500 won't disengage but if the NV4500 trans. isn't in it will disengage just fine
When the transmission is not installed, can you rotate the input shaft? If the transmission is in neutral, you should be able to rotate the input shaft freely. If it is in gear, the output shaft should rotate also, but at a different speed than the input shaft (or in opposite direction if in reverse). If you cannot rotate the input shaft at all, there is something broken/jammed internally and the transmission will have to be rebuilt or replaced.
Dec 14, 2015 | Dodge Cars & Trucks
83 yz 125. Split cases to find shifting problem. Can't see anything wrong. No broken gears, forks look okay. Can anyone give me tips on the next step?
does the selector drum rotate ok and is the gear selector shaft that the gear lever goes on straight and not tight in the crankcases.and have you checked the bearings on the input and output shaft are good.
Jun 13, 2015 | Motorcycles
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
1991 Hilux 2.8ltr diesel 5spd Man, stuck in 4th gear, won't budge, clutch still works.
Forth gear is when the input shaft is connected directly to the out put shaft by the sliding dog. 2 possible reasons 1 the pall that holds the selector shaft in position is jammed from possibly a broken spring ( remove the plug in the side/top of the box if you have one) or the connecting dog has broken a synchro ring and this is not allowing it to move back. It is possible that the inter connecting pin that prevents too shafts from moving at the same time is stuck as well.
May 31, 2013 | Cars & Trucks
My 2003 pontiac grand am clutch pedal stuck to the floor
Is it just sunk to the floor or actually stuck? Possible linkage broken, or broken return spring on clutch plates. If it is actually stuck, then I would guess jammed linkage or damaged input shaft splines.
Apr 11, 2013 | 2003 Pontiac Grand Am
1987 samurai rolls when off and in gear
Check the drive shaft first, ok, then the input shaft or main shaft inside the ****** is broken.
Oct 19, 2012 | 1987 Suzuki Samurai
Front drive line will engauge but front tires will not,88 jeep wrangler
I would suggest from your description that there are several possibilities.
1. Broken input PINION SHAFT.
2. Broken AXLE DRIVE SHAFT.
To check,
Get underneath and see how much that front Driveline rotates in each direction, More than 1/4 Turn is excessive backlash....Problem!!!
If it rotates freely...possible Broken PInion Shaft.
Raise the front wheels off the ground.Secure the Front drive line, get a friend to hang onto it, and wedge a foot against 1 front wheel, now try and rotate it. If it does, then that is the Junk one. Likewise, if it does not, then repeat on the other side. If that is OK, then it has to be the Transfer Box
Then you have a bigger problem.
Regards,DT
Aug 28, 2009 | 1988 Jeep Wrangler
Car wont move!
Sounds like the trans input shaft may be broken.If the input shaft, which is connected to the clutch, is not transmitting rotation to the inside of the trans then what you describe will occur.
May 15, 2009 | 2005 Dodge SRT-4
Rotor not spinning
Your timing belt has broken, u also have a balance shaft belt that should be replaced with the timing belt. Here are the part numbers of the belts from Gates web site: Timing belt #T090, Balance shaft belt #T089
Jan 11, 2009 | 1986 Dodge Ram 50
Eaton 700-016 Hydraulic Hydrostatic Mower Transmission Logo
22 people viewed this question
Top Eaton Plumbing Experts
Donni Steen
Tom Chichester
Are you an Eaton Plumbing Expert? Answer questions, earn points and help others
