Question about Eiki LC X999 Multimedia Projector
Eiki projector reset
I have a eiki projector LC-X990 and I have just replaced the lamp. However when I switch it on the red lamp light come on and nothing else happens. Do I have to reset the lamp life, I thought I could do it on the menu
5 Suggested Answers
SOURCE:
Marrie
  • 563 Answers
SOURCE: Display color problem, Eiki projector LC-NB2UW
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
Posted on May 14, 2008
SOURCE: Shuts off after using it for a while....Eiki LC-NB2UW
I have the exact problem. I have been using a portable fan next to the projector to keep it cooler it allows me to use the projector for work. I know that this is not the "fix" but it helps. If someone has the solution, I would like to fix the projector.
Posted on Mar 04, 2009
projdoc
  • 2239 Answers
SOURCE: Eiki LC-XG110 lamp going off
the lamp may be at the end of it's life.
Posted on Nov 18, 2009
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
How can you view the amount of bulb hours for an Eiki LC-986?
The manual for your projector is found here:
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_x986.pdf
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to
move a red frame pointer to SETTING Menu icon (refer to page 37).
Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
Mar 03, 2011 | Eiki LC X986 Multimedia Projector
Eiki lc-sd15 has no power. The lights do not come on when plugged in and nothing works.
near the lamp door is a small hole with a resetable thermal fuse under it, try to push pin carefully
Jan 18, 2011 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
I just replaced the lamps and the lamp 1 and lamp 2 lights are flashing red. the projector won't fire up.
The lamps are not in correctly. When the old lamps are taken out, it reveals two very small lever type switches that have to be down for the lamps to connect and for the projector to recognise the lamps. These switches can be seen in the section in between where the lamps go. They are about 4mm. Hope this helps. It happened to me.
Sep 17, 2010 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
Eiki lc-nb3s projector... fan comes on but no lamp then fan shuts down after about 5 seconds. Green "Ready" light and Red "Lamp" light are on... Have tried the reset button and cleaning the filter... no...
Mar 22, 2010 | Eiki Office Equipment & Supplies
How to check lamp hours on eiki lc - x50m
It does have a lamp timer but it is only accessible at start up if you hold down several buttons when you power the projector on. Eiki only supplies the info to dealers. I will see if I can post it later from my service notes.
Oct 19, 2009 | Eiki LC-X50M Projector
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
Mar 20, 2009 | Eiki LC XNB4 LCD Projector
Eiki LC X999 Multimedia Projector Logo
570 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Ekse
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
