Distorted screen when i play divx files and there is a fast movement in screen some parts of the screen seem to lag. Im not talking about the pixelated bad codec artifacts, but it looks like my video card cant handle it or something, it like distorts one half of the screen. Is this a common problem? I use windows mediaplayer classic with all the latest codecs Its a core 2 duo t7100 with an nvidia gforce 8600m gs. thanks in advance, Arjen Klaverstijn
  • 76 Answers
Use VLC player for all your media playing needs ( no need for divx codec downloads)
Posted on Sep 27, 2007
SOURCE:
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
Tip
Wanna create DivX Home Theatre Movies for your standalone DVD player
My essential MPG tools bundle is now here included are all the required plugins and tips and tools you will ever need to create and edit your own DivX
http://rapidshare.com/files/333638973/DIVX_AVI_Tools.zip
http://depositfiles.com/files/24ky1h4bt
DivX codec bundle includes the v6.8.5 community codec known the work with most DVD players as long as the FOURCC codes is DIVX or DX50 you will need to go pro if you want to use the DivX Convertor the best choice to create Home Theatre DivX media for use with Standalone DVD players.
The latest bundle includes the v6.9.1 codec and H.264 Decoder v1.1.0
This convertor costs about $30 if you include the DivX Converter MPEG-2/DVD Plug-in
Virualdub v1.9.8 by Avery Lee need say more this Guy can convert my DivX anytime I have included some32bit plugins and the BT8X8 plugin you will also need AC3ACM v1.4 by fccHandler that I have included.
DVD Decrypter v3.5.4.0 -Lighting's first and best decrypter of CSS for DVD-Video use this in the IFO mode and you can use AGK to easily create 800MB DivX versions of the main film, the burning functionality has been developed inImageBurn v2.5.0.0
AutoGordianKnot v2.55 - Allows you to easily encode Xvid and DivX files from a decrypted DVD with IFO files created from DVD Decrypter. Just select the size and codec DivX 350MB for example and off you go. Requires the DivX Codec to be installed for this functionality.
AVIDemux v2.5.1 - Deals with packed bitstreams and allows you to adjust video framerate the audio time lag in milliseconds. Auto functions give you PSP, iPhone and Zune.
AVIRecomp v1.5.0 - Uses internally installed VirtualDubMod v1.5.10.2; Avisynth v2.8.5.2 and Xvid v1.2.1. This installs similar to AutoGordianKnot v2.55 but can't use DivX codec at the moment, allows re-size, cropping,subtitles and logo additions as well as audio conversion VBR, CBR and ABR.
I have also included the excellent KMPlayer v2.9.3.1428 this will allow you to test the audio synch delay/lead in real time using the menu option shown on the enclosed jpg, this will allow you to experiment until you find the correct lag/lead do you can use this in one of the above programs to fix the audio lag/lead on you MPG4
password : www.windowstipsclub.co.uk
Join me on my facebook page for links and more tips the main site is still under construction.
on Jan 11, 2010 | Philips DVDR3380/05 DVD Recorder
Movie Cube multimedia player Q120 file format
Hi there just checked my manual for compatability! It doesn't mention divx it's xvid compatible! But im sure i have divx on mine that i have ripped myself
Jan 06, 2010 | Electronics - Others
I have a portable Kawasaki DVD player. It does not play AVI videos. Tellme what to do please.
This normally depends on what FOURCC the AVI has encoded inside the file.
Look here at my DivX Rox!! facebook group for the correct DivX FOURCC that will normally work on most standalone players on AVI with FOURCC =DIVX or DX50
Most DVD players that have DivX support require these two FOURCC tags, DIV3,DIV4,DIV5 and DIV6 wont always work but sometimes you can change this without re-encoding using a batch FOURCC changer.
As a general rule of thumb even when you change the FOURCC of the AVI you may experience audio lag on the file it is best to convert all AVI's to DivX using the DivX Convertor that is available with the DivX Professional codec costs $19.99 (£13.99) and is well work the money.
I have had some success with Xvid AVI's with FOURCC XVID but with audio lag and video jerks.
Jan 06, 2010 | Philips DivX DVD Player
Im having Lag Spikes on xbox 360.
Call your ISP and have them do a line test.
from your PC, go to www.speedtest.net and perform a speed and latency test.
Give this info to your ISP.
Jun 23, 2009 | 2wire (1000-000057-000) Modem
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
LG HT762 DVD Player won't play divx anymore?
Try to unplug the player for a few seconds and then plug it back. It should work again with the DivX files. I had an identical problem and since then, it works just fine.
Apr 02, 2009 | Televison & Video
Philips HTS 3565 system doesn't play MPEG-4(.mp4) formate. TV screen doesn't show the mp4 file, but DIVX files are readable. Can u help me to solve the problem.
HTS 3565 this model does not supports the MPEG4 video format, but you can play MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra, WMV all these formats.
Mar 26, 2009 | Philips HTS-3565 Theater System
I cant play a cideo
The viewty will play .avi (divx) and MP4 files providing the display resolution is not above 320x240. If the the display resolution is above this for either format, you will receive a "file type is not supported" error. Please be aware that the viewty CAN play Divx .avi, Xvid .avi, .3GP and MP4, but only if they are not above that resolution.
Jan 28, 2009 | LG KU990 Viewty
Open Questions:
\Q;- TOSHIBA customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This TOSHIBA USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 TOSHIBA USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the TOSHIBA USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, TOSHIBA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA USA Calling TOSHIBA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA USA's phone numbers against each other. Contacting TOSHIBA USA in General While [+I8OO-8O3-1O69] is TOSHIBA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA USA.
Oct 18, 2019 | Toshiba Computers & Internet
Computers & Internet Logo
255 people viewed this question
Ekse
Alun Cox
