Question about Jandy 01 - Ei Power PCB Assembly
Board keeps blowing fuses when plugged in/
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
AC fuse keeps blowing on my 1998 ford crown victoria
The reason a fuse blowing may be because of a short circuit. And you should check any wire connectors that plug into the pc board.
___________________
fiat km tool software
Jun 15, 2012 | 1998 Ford Crown Victoria
The fuse on my circuit board keeps blowing after a thunder storm. Need to replace the entire circuit board for my RS8 system. Any sugestions on where I can purchase just the circuit board? Mike
unplug all the aux plugs but mark them replace fuse turn on if it still blows need a new board if not plug in auxs 1 at a time till it pops then check out that aux for shorts sometimes the relays short out
Mar 17, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
My fuse keeps blowing when i plug the tv in. It was working fine and then just blew a fuse. Now every time i put in a new one, it blows instantly when plugged in.
That could be caused by either the AC main filter board ( Most Likliest) or also the deflection board. You can get replacement boards from www.tvrepairworld.com and free assistance to help determine which board has the issue.
Jul 10, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Dec 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Dishwasher
There is a short there, in control panel circuit board,that's why your fuse is keeps blowing.Trace the electrical connection from down to up to control panel board. Check for short capacitor and diode..Feel free to ask whatever the result..
Hope this may help you;
DON'T FORGET TO RATE;
Sep 03, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Blowing fuses
Maybe the audio amplifiers IC are in short circuit or the alimentation board are damaged
Aug 16, 2008 | Audio Players & Recorders
Fuse keeps blowing
Have him check power suply link, from fuse to wall plug, theres a short some where between the plug and the fuse.
Jan 13, 2008 | Kenmore 19001
Jandy 01 - Ei Power PCB Assembly Logo
52 people viewed this question
Top Jandy Electrical Supplies Experts
Steve
Gene Haynes
Are you a Jandy Electrical Supply Expert? Answer questions, earn points and help others
