Question about RCA RP5610 Clock Radio
Setting up the clock on my RCA 5610A - RCA RP5610 Clock Radio
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
RCA Model RP3765 manual
Hi Arlene, Your clock should actually set its own time if the two Double batteries are installed. If not click link and follow instructions RCA RP3765 User Manual Setting The Clock Setting Clock
Good luck
Nov 04, 2014 | Audio Players & Recorders
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
How to set clock
Follow below procedures to set the clock..
1. Press CLOCK until the time flashes on the display (12-hour clock for RCA, 24-hour clock for Thomson).
2. Press TUNING UP or DOWN to set the hour and then press PRESET UP/ DOWN to shift to minute digits.
3. Press TUNING UP or DOWN to set the minute.
4. Press SET to save settings and STOP to quit setting.
Note: When system is ON, you can press CLOCK to
display the current time for about 2 seconds.
Regards,
Jeep Brainy
Sep 19, 2009 | RCA RS1285 CD Shelf System
Set the time? ge model #75350.
Download the manual here:
http://www.devicemanuals.com/guide/CD%20Player/RCA/RCA-75350-User-Manual-==TVRJMk1UZ3k=.html
Or open the battery compartment on the right side and press the clock button, >> or << to set time, and press clock button again to save.
Mar 30, 2009 | GE Spacemaker (74290) Clock Radio
Do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Mar 13, 2009 | RCA Radio Alarm Clock
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
No manual
Follow the procedure to set time/ clock.
Setting the clock
1. Press and hold CLOCK until
the hour flashes on the display.
2. Press << / >> to set the hour
and then press CLOCK to shift
to minute digits.
3. Press << / >> to set the minute.
4. Press PROG•SET to save
settings or STOP to quit setting.
You can download user manual at RCA Support.
Regards,
Sep 07, 2008 | RCA RS2663 Shelf System
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
RCA RP5610 Clock Radio Logo
69 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
