Question about Unitech MS840, Laser Imager, Interface USB, Base P/N MS840-MUCB0S-SG
I just bought a new unitech 840ms scanner to replace the old on. I did what instructuon told m. I got it to connect and I could not scann the itrems.
I have a Tatung VCR, have lost the instructuons
look up where you bought it from then either send them a message or talk to them and ask them about the vcr
Apr 05, 2010 | Video Game Consoles & Games
How do I set a Unitech MS 180 up?
The scanner receives energy? If yes, then it need to be reconfigured, with the user manual. If not, then there may be problems with the cable or connector, check or change it.
Sep 16, 2009 | Unitech MS 180: MS180-1KG Handheld Barcode...
Total available char can be scan
The number of characters read is defined in your application and the width of the printed bar code. Also the width of the laser or ccd. One program to develop applications JobGen Plus de Unitech.
Roberto Martinez
Aug 16, 2009 | Unitech PT630 Portable Terminal
I just recieved the Unitech MS 183 barcode scanner. The unit when pluged into the computer, will scan one barcode then shut off (The red receptive light no longer appears) and the one barcode scanned will...
The scanner has several modes of operation after reading a barcode. But I comment it may be bad configuration. Check that the mode of connection is correct (usb, keyboard wedge, RS232, etc.). All this programming is done with the user manual, through configuration barcodes. If you do not, then you can download from www.ute.com.
Regards.
Roberto Martinez
Aug 13, 2009 | Unitech MS 183 (MS183)
I still can not find the cold boot button on my PA962 unitech .
That's a procedure. Read the below mentioned :-
http://www.unitech-utp.com.tw/content/service/FAQ.aspx?&Page=6
Thanks.
Jun 13, 2009 | Unitech PA962 Portable Terminal
Won't scan credit card
You didn't indicate what you are attempting to scan to, but the scanner won't just "scan" the card, it will send the data it reads to an application that is monitoring the connection from the scanner.
Verify that the scanner drivers have loaded properly and then make sure that the capture application is running and looking for the scanner connection.
May 12, 2009 | Unitech POS Keyboard K2724 (K2724-B)
Will not read barcode correctly
La configuracion por defecto en el lector puede necesitar cambiarse para el tipo de codigo de barras que intentas leer. Descarga el manual para cambiar los parametros del tipo de codigo de barras que intentas leer. The default setting in the reader may need to change the type of barcode you are trying to read. Download the manual to change the parameters of the type of barcode you are trying to read.http://www.ute.com/files/manuals/103_MS210%20Users%20Manual.PDF
Dec 20, 2007 | Unitech MS210 Handheld
How to hook up?
This scanner may have a parallel and a USB port. Use the USB port, if it exists. If not, connect the scanner to the parallel port, then connect the printer to the pass-through port on the scanner. This can be problematic, requiring changes to the BIOS and driver difficulties. A USB scanner is a better solution, and they are cheap nowadays.
May 21, 2007 | Acer ScanPrisa 640P Flatbed Scanner
Unitech PT630 files
What program are you trying to replicate? Is it a third party application? What error you received on the PT630 screen when u run the program.
Dec 30, 2006 | Unitech PT630 Portable Terminal
Unitech MS840, Laser Imager, Interface USB, Base P/N MS840-MUCB0S-SG Logo
27 people viewed this question
Top Unitech Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Unitech Office Equipment and Supply Expert? Answer questions, earn points and help others
