I bought a 2wire 2701HG-B from an individual. How do I change the PPP Login settings that are already filled in with another username and password during onlin configuration?
You will have to login to your modem's configuration panel. To access this, you will have to use a computer which is connected to the router via an Ethernet (CAT5) cable. Once you are at such a computer, go to Start>All Programs>Accessories>Command Prompt (Or just go to Start>Run, type in: cmd
then press OK).
After Command Prompt loads, type in: ipconfig
Now press the ENTER key on your keyboard to execute the command. A list should be returned. You will want to locate the IP address associated with the, "Default Gateway." This is demonstrated in the screenshot located here.
Afterward open up your Internet browser (Internet Explorer, Firefox, Chrome, etc...) and type the IP address associated with the default gateway into the address bar. In the case of our previous example, you would type, "192.168.1.254" into the address bar (without the quotes and without adding www. or .com). Then press enter to visit the page. Your modem's configuration page should appear. You will want to click the link reading, "Run System Setup Wizard."
Afterward you might be asked to provide a password. If you don't have or know your password, try the default of blank. If that doesn't work you will have to call AT&T technical support for assistance in resetting the password.
Once you have reached the setup wizard you should be able to configure the modem to include the new registration information.
Let me know if I can assist you with anything else.
