Question about Vehicle Parts & Accessories
I own a 2007 Hyundai Azera with an aftermarket Astrostart RS 613 winter remote car starter. Remote worked fine for 5 yrs. I just installed 2 new batteries in the key fob. Now key fob locks & unlocks car doors fine but when I press the start button on the key fob the parking lights come on as normal but the engine cranks over but does not start. Please help, thanks
  • 13 Answers
SOURCE: Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Posted on Mar 30, 2008
SFroese
  • 141 Answers
Sounds like the circuit that engages the starter system is not working. Are you able to trace the wiring that goes to the ignition harness?
Posted on Sep 06, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
SOURCE: remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Posted on Jan 11, 2009
ltfrc
  • 227 Answers
SOURCE: how do auto remote car starters work?
Usually the car start system has a "Valet" switch hidden somewhere under the dash or in the glove box. This is used to disarm the system for when the vehicle is serviced. You will have to locate and turn the switch on, some units have a small push button. In either case it is a good dea to locate it for future use.
Posted on Feb 08, 2009
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Nov 24, 2015 | 2007 Jeep Wrangler Unlimited Rubicon 2...
I bought a new astroflex remote starter and it won't program to my 2007 hummer h3
If its new it should still be covered by the warranty Astorstart support services will help you get it paired.
Technical Support: E-mail: support@astrostart.com Hours: 8:30 a.m.-7:30 p.m. ET, Monday-Friday 10 a.m.-2 p.m. ET, Saturday Find a Store (by phone): Find a Store (online): Store Locator
Nov 25, 2014 | 2007 Hummer H3X
2007 Azera doors will not lock with remote or lock button in the car. Unlock works fine.
well it is not your relay ,,codes need reset ...go to autozone they will reset your codes
Oct 26, 2013 | 2007 Hyundai Azera Limited Sedan
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
2007 hyundai azera trunk lock
I have a 2012 Azera and had the same trunk lock problem -- there is a security cutout switch located in the top center of the glove box opening which can be tripped if the glove box contents stick up over the lip of the opening. This switch disables the truck release on the dash and on the remote fob. On earlier Azera's the switch is located on the left side of the glovebox opening.
Mar 17, 2012 | 2007 Hyundai Azera Limited Sedan
2007 hyundi azera trunk lid not working. Remotes
The answer is in your glovebox. There is a trunk lock-out button on the top left. It is designed to prevent access to the trunk if using a valet (or anyone else driving your car). Go to your glovebox and press the button. The trunk should now work as intended.
Jul 13, 2009 | 2007 Hyundai Azera Limited Sedan
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
