Samsung model s42axyb09
Clicking sound when trying to turn on tv
5 Suggested Answers
  • 8457 Answers
SOURCE: samsung tv clicking sound
It ur power supply board it have components,is dead could be anythings,Capacitors bulbging happen mostly only on DLP Tv bacauce the FTB transformer,give high voltage for projection.Tries thes websites for replacement power supply board.Shopjimmy.com,Tv Repair World.com,Partstore.com or Ebay.com.
Posted on Sep 26, 2009
freelance-au
  • 131 Answers
SOURCE: clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Posted on Apr 05, 2010
SOURCE: I have a Samsung LCD model#LN-T5265F and my tv is
Hey, i am now having the same problem as most ppl with the Samsung TVs. I have a LNT-5265F which I bought in 2008 (so only 2yrs old). It now only makes a clicking noise (blank screen). The clicking noise is roughly every 3 secs. Based on research I believe it is the bad capacitors issue. Can someone tell me if the power supply board is still under warranty? Also, what type of capactitors are recommended to buy for replacement? and worst case what is the p/n for a new power supply board for my model?
Also, I watched the videos showing you step by step on how to perform the repair on your own, but little bit confused about the "Hot" vs "cold" on the board? Sorry for all the questions. Thank you!
Posted on Jul 30, 2010
SD Tech
  • 14553 Answers
SOURCE: Samsung PN50A450 wont turn on and is clicking.
Many sets use a mechanical relay which may be what you heard.
Based on what you have told me here with your question I agree first place to look is power supply.
All sets have as part of the power supply a standby supply that runs all the time when set is plugged in---it supplies the voltages for the remote or manual on and off to power the main supply and with it the set to be turned on.
You are able to safely get the back off---lay set face down so entire screen is supported evenly---no downward pressure as the screen unit can be instantly destroyed.
Most sets have to be taken apart this way if a base is attached as it will have to come off to get all the cover screws off.
You may be on the right track with filter caps---that standby runs them all the time and the material in cheap caps can dry out in less than two years--using cheap ones cuts cost when making the set.
I will attach a few photos of what to look for---one is a mild example and another has some extreme examples---if locate one or more I can explain how to replace and identify their values--not hard as each have only two leads soldered in--values are actually marked on the parts--each has a plus on one side and a minus on the other.
let me know if you find bad ones.
look for perfectly flat tops like on left===right one is just slightly puffed up and is still bad.
The ones with arrows are extreme examples and some of the others look ok.
Posted on Jun 14, 2012
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Hi my tv sounds like it start but it wont como on i change the power board but still did the same what could it be thanks
Samsung 52" TV Repair - Won't turn on Clicking Sound ...
? 9:37
https://www.youtube.com/watch?v=2WpSJy_kANs
Apr 13, 2012 - Uploaded by Kathy Burton
It makes a clicking sound several times before it turns on, seems to ... Samsung 52" TV Repair - Won't turn on Clicking Sound ...Maybe it took a little longer than that, but I was happy. ... My TVworks like new. ... Samsung No Start / Clicking Repair - 52" LCD HDTV - Duration: 8:26. by clipdan 169,453 views.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and ... hi my tv flashes red and bluebut wont turn on.
Dec 12, 2015 | Televison & Video
sir cancating filed ho ta hai
Oct 18, 2013 | Televison & Video
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Mar 20, 2009 | Televison & Video
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
331 people viewed this question
Top Televison & Video Experts
Electro Med Services...
