Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Bios settings NX - Dell Dimension 9150 (DIM915MIN) PC Desktop
Error code 0x0000005d
Sign in to vote
Error Code: 0x0000005D: Your CPU is not compatible.
To install Windows 8 Release Preview on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system.
To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled") feature, within the BIOS security settings.
If the BIOS setting for the NX support option is not available on your system, you may need to contact the manufacturer for updating the BIOS. Note that some older processors may not contain these features and will be incompatible with Windows 8 Release Preview
Mar 05, 2014 | HP Cobra Motherboard Asus P4sd-la Pentium...
Dell Demension e520
These features are a functionality of the Processor used in the Desktop. These features are NOT a feature of the desktop itself and is limited to functionality of the CPU exclusively. Refer to this link for more information regarding NX, PAE and SSE2. http://windows.microsoft.com/en-us/windows-8/what-is-pae-nx-sse2
It is STRONGLY recommended you do not mess with these settings in the BIOS unless you REALLY know what you are doing.
99.9% of the time NOONE messes with these settings you should have no reason to do so.
Jan 08, 2014 | Dell Computers & Internet
Gateway 505GR update bios to have NX?
Do not upgrade to windows 8, with this computer.
If you wish to use windows 8, please purchase a newer computer.
You will only cause headache for yourself and other people by attempting to run windows 8 on this old computer.
Thank you.
Ekse
Jan 18, 2013 | Gateway 505GR PC Desktop
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
Hi Can anyone tell me how I can get into the bios On a compaq nx 8220 F10 does not work it does say 163 time and date not set. i am trying to set the bios so I can override the admin passowrd as it has...
hmm I know the newer models of Compaq use f10 try f1 f2 or the delete buttons, most of the older models use these f keys to access your set up menu to your bios.
May 30, 2011 | Computers & Internet
How to entering bios set up to nec versa pro nx series
Nai,
If you do not now how to enter BIOS then I would recommend that you should not play with BIOS settings as once disturbed they may alter the behaviour of the computer.
However, should you still want to do that then just remember that to enter BIOS you have to press F2 (or del key in older computers) immediately after powering it on. And to exit press F10 to save the changes and exit or esc to exit without saving the changes.
Mar 14, 2011 | Computers & Internet
How can i clear bios from hp compaq nx 9010 notebook
Are you wanting to clear thr BIOS password? IF so the only way to do it on a laptop is to pull the CMOS battery out. Then boot the computer up to BIOS and it should be cleared, then just reinstall the battery.
Mar 10, 2009 | HP Compaq nx9010
My hp compaq nx 6310 wont start up it asks for password what is this
This is a bios password that is set up in the actual bios. someone might have set this up inadvertently.
Feb 25, 2009 | HP Compaq nx6310 Notebook
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
Alun Cox
