Question about Bandsintown Concerts by Bandsintown
Bandsintown app map location is wrong - Bandsintown Concerts by Bandsintown
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
Nov 16, 2016 | Tablets & eReaders
Apps when wifi not available
Have mobile data on your phone plan .
activate mobile data on the phone.
at the top of the screen put your finger on the top of screen and slide down.
Samsung phones have a hidden setting window
then slide finger from right to left as mobile data option just slightly off the screen.
you will also notice a location option. maps needs this to be on to locate your gps position
Aug 15, 2016 | Samsung Cell Phones
Sat nav fault shows location in Warwickshire I am in manchester
report to your GPS manufacturer using details such as
brand
model
make
version
serial number
map version
date
location in X,Y coordinates
perhaps pic of a popular place superimposed with your GPS
screen
http://www.gps.gov/support/user/mapfix/devices-and-maps
http://uk.support.tomtom.com/app/answers/detail/a_id/1834/~/how-can-i-report-a-map-error%3F
How To Report Map Errors Quickly and or Permanently TomTom EN
Apr 05, 2016 | Cars & Trucks
Can I get Maps for australia
Download the app Maps.me and download the map of Australia. It's all free and convenient. Using the app does not require internet or mobile data. Just download the app and the map then make sure switch on your location services.
Sep 22, 2015 | Magellan Roadmate 9212TLM GPS
I have recieved a message from =919872420100 its not opening
Since the last Maps/Search update my Google Now keeps saying that Location Services is Off and to turn it on. However everything is turned on as it always has been. Many apps can't find a location including Foursquare, weather apps, etc. Here's what I've tried and nothing has worked.
- Full reboot
- Uninstall to factory Maps. Didn't work so reinstalled update
- Uninstall to factory Search. Didn't work so reinstalled update
Jul 08, 2013 | Computers & Internet
Can't add photos to bandsintown app on Facebook
This is a Facebook bug that is being looked into, in the mean time if you email feedback[at]bandsintown[dot]com with a link to the event as well as the image, the support team can set you up in the mean time.
Dec 12, 2012 | Bandsintown Concerts by Bandsintown
How do I save current location in Google maps? On my previous phone I could save my current location using OVI Maps, give it a name, sync it with the OVi server etc. I can't seem to find any way to...
When you are in Google maps, click on yourlocation and you get the details page. In the upper right corner there is anoutline of a star. Touch that and it turns yellow and addsthat location to "Starred places". You can access it anytime from maps bygoing to menu, starred places. Hope I helped you
Jul 11, 2011 | AndroidCrowd Android Apps
I want to know how to use the GPS
what part of the gps system do you want to use
nokia maps?
gps data?
nokia sports tracker?
google maps?
all these apps use gps but to get the most out of them you need internet on your phone but they are not neccersary but having it makes your expriance so much better
firstly go outside and go to gps data and it should search for satalights if you go to posistioning then click options then satelight status this will show the signal and lock of satelights
the bars shows the signal quality the more of the bar better signal but when they become solid coloured in that means that the phone has locked to the satelight
once the phone connects to several staelights then under positioning your posistional information is given
then you can go to the sevreal maps aplications
all the maps apps work better when you are moving they are not accurate when you are not moving
nokia maps is free for a year then you have to pay
google maps is free
both of these are navigation apps
sports tracker is a app that tracks your movements on a map which is pritty cool
using the apps is pritty simple and you learn to use it quickly
aalso the more you use the gps the quicker the gps finds your location the first time will take a minuite or so
Nov 11, 2009 | Nokia E71 Smartphone
Wrong location on maps
Download the GPS tracker app, and your location will be A LOT more accurate.
the same thing happened to me before I downloaded the app, and now It shows my exact location 98% of the time.
Jan 25, 2009 | HTC G1
Bandsintown Concerts by Bandsintown Logo
Top Bandsintown Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Bandsintown Facebook App Expert? Answer questions, earn points and help others
