Question about SanDisk Sansa e260 MP3 Player
Always perform the selected action button....
I have a big problem. on the main menu, I accidentally pressed the always perform the selected action button and went to the media convertor and now I cant go anywhere else! Can someone help me>
  • soup613 Sep 29, 2007
    Thanks. The reason I gave U a 3star in the beginning was cuz i went to my documents the whole time!
  • 626 Answers
You can right click on the device name under My Computer and select Auto Play. It will give you all of the options available. Please add to the question if you need furter assistance. Best of Luck.
Posted on Sep 26, 2007
How do I reset the nabi tablet.
  1. Turn off your nabi Big Tab.
  2. Press the Volume - button first, then press the Power button and hold them both until the system menu appears on the upper left corner of the screen.
  3. Use the Volume - button to highlight "Recovery Mode," then press the Power button to select it.
More items...
I Need to Perform a Factory Reset on My nabi Big Tab
https://www.nabitablet.com/.../nabi.../i-need-to-perform-a-factory-reset-on-my-nabi-big-... How do reset the nabi tablet Google Search
Dec 17, 2016 | Tablets & eReaders
How do I perform a factory reset on Nabi Jr. Daughter uncertain her info on it??
A factory reset will wipe all data including installed apps. Make sure the battery is fully charged before beginning this as you could "brick" your Nabi. Here's the video I used with the procedure on it: https://www.youtube.com/watch?v=T-bamfAKvgk
Steps are:
  1. turn it off
  2. hold power and vol + button until menu appears
  3. press vol - to highlight "recovery kernel"
  4. press vol + to select it
  5. press vol - and vol + at the same time
  6. menu will appear use vol - to select "wipe data factory reset"
  7. press power button to select it
  8. press vol - to select "yes delete all user data"
  9. press power button to select it
  10. this will perform a few actions and take you back to the menu from step 6 should already be on "reboot system now"
  11. press power button to select "reboot system now"
  12. the Nabi will reboot and reset to factory defaults
Dec 26, 2013 | Computers & Internet
How to use microsoft excel to draw a table
When you select the cells you must press a button for mark lines of cells (it has lot of cells with bold line or lines which tell you where will be line). You can mark upper line, or left or right line of cells. Marking the cells you can build the table. Always select cells which you want to mark. You can connect two or more cells together for creating big block of cells, too. You must just found that two buttons or function on menu. Always use selection first, and than press for some action (change color...)
Aug 24, 2011 | Office Equipment & Supplies
I want to reset my phone
  • Press the "Menu" button. This button is not labeled. It is the button at the very top right-hand corner of your phone's keypad.
  • Use the arrow keys to highlight "Reset Defaults." This is found near the bottom of the menu options.
  • Press the "Select" key. This is the unlabeled button at the very top left-hand corner of the phone. As explained by the user manual, a message will appear, prompting you to confirm the action. This is to safeguard against accidental resetting, because resetting your phone will delete all your saved personal information.
  • Press the "Menu" button to confirm that you want to reset the phone to its factory conditions. Your phone will now reset and revert to its original factory settings.
  • Regards
    Jun 27, 2011 | Panasonic Lands Phones
    I have a Sanyo DP26746 TV. I pushed the reset button in error and am unable to get to any other screen. It wants to look for HD channels. Since I only use a satellite service it can't find any. Help! I...
    First of all make sure all the leads are connected to the TV.
    Press the reset button on the remote twice (this will clear all previous settings) and perform a channel search and create new ones.
    Now you will need to perform an all channel search.
    Press the Menu key to display the main menu.
    Use the cursor up/down keys on the remote and select "All Channel Search" and press enter. Use the cursor key to select yes and press enter.
    Now you may need to perform a digital cable search to pick up your satelite digital signal.
    Press the tuner key on the remote and then the menu key.
    Use the cursor key to select Digital cable search and press enter.
    Now the TV should scan for a digital signal
    Good luck and kind regards.
    Jun 25, 2010 | Televison & Video
    Error 55.1 and also language need to change english
    get the relevant firmware update from the hp website and update the firmware ( I think there is a firmware update manager for hp printers so maybe check that out )
    Also with regards to changing to english you may be able to do that through the web interface using its ip address or if you do the following
    Set the default language and paper size by performing the following:
    1. To start press the button (CANCEL JOB) to make sure that the printer is on ready state.
    2. Press the button (SELECT) to enter the main menu.
    3. Press button (RIGHT ARROW) one time to enter on main menu / system setup.
    4. Press the button (SELECT) twice to enter the system menu / language.
    5. Press button (RIGHT ARROW) until you get the desire language.
    Apr 20, 2009 | HP Color LaserJet 2600n Printer
    Black square in center of screen - no "closed caption" solution
    Here are the steps from the owner's manual:
    1. Display MAIN MENU. Press ACTION key on remote.
    2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key.
    3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET.
    4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF.
    5. Press ACTION key three times to return to normal screen.
    You can download the manual from Panasonic here if you need a copy.
    Apr 03, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
    Can't get codes
    I have just found the solution to the problem (2 minutes later XD)
    Quote CodeJunkies' Support site:
    Try resetting the Action Replay by following these steps:
    1. Insert the Action Replay into the DS
    2. While the Action Replay software is loading, press and hold all the following buttons: A + B + Start + Select.
    3. Release all of the buttons once the Action Replay is at the main menu.
    The first screen should persist for much longer than normal, and when the Action Replay DS main menu loads, your hardware should be reset.
    Once the reset has been performed, try connecting the USB cable to your PC, opening up the code manager software and transferring data again.
    It won't return all of your games back, but it will allow you to start on a clean slate again. (Using the update feature will bring most, if not all of your games back
    Aug 20, 2008 | Datel Action Replay for Nintendo DS
    Waiting for GPS
    From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
    With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
    On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
    Feb 17, 2008 | Navman iCN 320 GPS Receiver
    Canon i70 LED
    The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
    Try This
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
    (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button.
    (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
    (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    During initialization, the LED blinks in
    green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    After the function (menu) is selected, press the Power button. The LED lights in green, and the
    selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    *** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
    Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
    SanDisk Sansa e260 MP3 Player Logo
    29 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Computer Repairing
    Computer Repairing
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
