Question about HiTi Digital HiTi P720L Photo Printer, 300x300 dpi Resolution, USB 2.0 Hi Speed, Dye Diffusion Thermal Transfer, 100V-240V Power
Error cam 01 - HiTi Digital HiTi P720L Photo Printer, 300x300 dpi Resolution, USB 2.0 Hi Speed, Dye Diffusion Thermal Transfer, 100V-240V Power
Cam motor or sensor fault.
Hello Abdul,
Sorry to hear that you are getting a CAM mis-position error 09:00 / 09:01.
Please check the following;
Open and close the lid. Listen very carefully. Can you hear a motor running for a few seconds and then stopping?
It may be a simple belt / pulley issue.
This PDF document should help you find the cause.
http://www.magicardonline.net/temp/cam_mis-position_error.pdf
Let me know if you need anything further.
Kind Regards,
MC.
Apr 19, 2014 | Magicard Rio 2e - Ethernet - Single-Side...
Sony E:91:01 error on screen. what can i do to fix or remove it... thank you (on my handy cam)
It needs to go to a Sony Camcorder Repair Centre for repair. This may cost a fair bit and bear in mind a replacement Digi Cam starts at less than £90 !
Mar 02, 2011 | Televison & Video
Error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Jul 06, 2009 | Sony Cyber-shot W110 Digital Camera
Error 91:01 and flash wont work..
I believe there is lots to do ... Here is a link that I cam e across. I haven't tried the steps given on that link however I can see that it has helped other with the same problem. Here is the link:
http://www.agoraquest.com/viewtopic.php?topic=8624&forum=31
Hope that would help.
Regards,
Srinivas
May 19, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
ERROR C:13:01
I had the same problem... just switch on the cam with the memory card in it.  Then go to menu, and in that find the FORMAT option and format the card.  That's it.... ur cam should work fine now!  Let me know if it was successful!
May 04, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony T5 is flashing Error E91:01 and the pictures are blurry
My Sony cam was woring fine but suddenly it started giving an error E91:01 which is continuously flashing
Aug 27, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
HiTi Digital HiTi P720L Photo Printer, 300x300 dpi Resolution, USB 2.0 Hi Speed, Dye Diffusion Thermal Transfer, 100V-240V Power Logo
52 people viewed this question
Top HiTi Digital Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a HiTi Digital Office Equipment and Supply Expert? Answer questions, earn points and help others
