Question about Texas Instruments TI-84 Plus Calculator
How do I get a neg. 3 and not the minus 3 - Texas Instruments TI-84 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Use the (-) key just to right of the decimal point key.
Posted on Jun 02, 2014
Hooking up a awes12p 1100 watt subwoofer do u hook positive to positive negative to negative on the speaker
Hello there,
It depends on How many amplifiers you are using and whether the amp is runniong in 'bridged' mode (turns a stereo in to a double power mono. Then after that, it depends on what the RESISTANCE is that the amp will drive. because these Speakers have 2 coils of 4 ohms EACH. SO... (you can look this up if it is any easier.) For a 2 ohm speaker, you wire plus to plus and neg to neg and for 8 ohms you wire plus to minus and then amp neg and plus to othjer terminals.
I KNOW it sounds complicated because electronics is !!!! ...SO here is a page showing HOW to wire them you. Just click on the picture for your Amplifiers set up. and connct as shown.
http://www.sonicelectronix.com/item_2234_Audiobahn-AWES12P.html?show_tab=3
It's ALL about the AMPLIFIER !!!!! and what it is 'driving' You must match speaker resistance / impedance to amplifier to get maximum power transfer.
Sep 14, 2014 | Car Audio & Video
New starter wont start just click
Will it jump start? What shape is the battery in?
Mar 23, 2014 | Dodge Grand Caravan Cars & Trucks
I can't get rid of the zero in front of the minus, add, multiply and devide sign. how do i get rid of it?
Are you entering any number before pressing the minus, add, multiply, or divide key? Those operations require two numbers; if you don't supply the first one then the calculator will supply the previous answer, which was zero.
For example, to add 2 and 3, press 2 + 3 = and you'll see 5. Now to add 4 to that, press + and the calculator will automatically supply the 5. Press 4 = and you'll see 9.
Oct 08, 2013 | Sharp el-531x scientific calculator
Battery possitive closer to windshield or neg?
Positive is red,negative black.Should be a plus sign and minus sign by terminals.
Dec 14, 2012 | 2003 Kia Sorento
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Nov 06, 2012 | Eagle Cuda 242 Fishfinder
How can I ground my cable under the hood of a volvo s80 t6 2000? I see a positive but no ground?
YOU FIRST NEED TO DETERMINE WHICH IS
GROUNDed Plus Or Minus. I assume you are refering to hooking up jumper cables. If it is a negative ground system You hook neg. cable (Black)
anywhere on frame. Red or positive on Pos post.
Dec 31, 2009 | 2000 Volvo S80
How can i raise to a negative power on TI-30xa
Use the Y to the x key [Y^x]. To enter the negative exponent use the change sign key [+/-] not the regular minus - sign.
Hope it helps.
Sep 29, 2009 | Texas Instruments TI-30XA Calculator
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
Texas Instruments TI-84 Plus Calculator Logo
14 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
