Question about Hunter Ceiling Fan Light Switch Control
Wattage limiter hunter ceiling fan - Hunter Ceiling Fan Light Switch Control
  • 3,382 Answers
As per the Energy Policy Act of 2005, all ceiling fans manufactured or imported into the United States must utilize a light bulb wattage limiter as of January 1, 2007. This limiter limits the capacity of the fan's light kit to a maximum of 40 watts per bulb. Not very bright at all!
Put in LED lamps and save a lot of work. Go to: http://www.youtube.com/watch?v=7WeWSKNe64A it will show you how.
Posted on May 13, 2014
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
  • 7 Answers
SOURCE: Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Posted on Jun 27, 2009
  • 10865 Answers
SOURCE: How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Do you have mod.#98480x light limiter A
This is a wattage limiter inside the the fan. If you have replaced the lamps recently, you have probably put in those with greater wattage than permitted. Replace the lamps with same as original. If it still flashes, you could remove the light limiter and wire direct.
Mar 13, 2015 | Hunter 52" Ceiling Fan With Light
How do I stop my ceiling fan light from flashing?
Make sure the wattage is correct. If it is then try a lower wattage.
Oct 03, 2014 | Hunter Dryers
Watt generator ceiling fan
So each fan or fan/light uses only the max wattage allowed by the government.
Aug 11, 2014 | Hunter Dryers
Lights in ceiling fan flicker when turned on
Make sure you have the correct wattage for the socket!
Mar 29, 2014 | Hunter Dryers
98480x
Can you elaborate more on the damage etc and how you have a solution
May 31, 2017 | Hunter Ceiling Fan Light Switch Control
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Mar 01, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Dryers Logo
614 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
