Question about Refrigerators
Frigidaire Side-by-Side Built in
How do I roll out a built in that has leveling bolts at the front so that I can clean beneath it? It is a Frigidaire Side-by-Side cabinet depth built in model KSB525FKBL01
  • 114 Answers
Adjust bolts until rollers are touching floor. Grab the unit low and on the outsides of both doors. It should then roll out fairly easily.
Posted on Sep 28, 2007
How to adjust the water level on Frigidaire wash machine
if its a front load machine it usually built-in the timer if there is no switch for it
Sep 29, 2014 | Frigidaire Washing Machines
What angle should the dishwasher be high in front and how high
the dishwasher should be level.....with the door open check this with a level held against the vertical metal frame at the front side of the dishwasher (where the door seal is attached). Adjust the front leveling feet....one at each side until the front is vertical.....you will probably need a wrench to do this as the feet/bolts are usually quite tight. Be sure both feet are touching the floor when you are done.
Mar 24, 2013 | GE Nautilus 24" Built-in Dishwasher
We have a Rockwood Signature ultralite travel trailer 8315bss and we would like to know why it is that we cant level the back of the trailer with the power jacks it seems like the left side is down and...
There is a certain amount of flex in the frame, but it is also possible you using the levels wrong. Are they built in, or are you attaching them as needed?
I would get a 4' level and put it in the middle of the floor.
Built in levels bubbles rarely work well because they are not long enough.
Level front to back first, and then side to side.
Jun 25, 2011 | Dodge Ram 1500 Cars & Trucks
Bottom drawer does not have a hard stop. Drawer will roll right off the door and on to the floor
check the level of the Dw per the instructions.. may need to raise the front up... If you take the front kick plate off( 2 screws) there are 2 white feet at the front... also phillips screws above(inset) that control the height of the back 2 feet.
Manual tells you where to place the level.. for plumb levelling the manuals stated to put the level on the front side of the cabinet( where the door closes on to)... on the vertical side. Adjust the front feet down, or the back ones upward( need to watch to keep the side to side level when doing this too...
Good luck
Oct 04, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
Pressure washer (gas)starts then immediately stops? not getting gas?
Check oil level as some are fitted with oil alert, if its been sitting it will have blocked jets. if its a briggs with a Quantum the bolt thats holds the caby bowl on has the main jet built in it. remove the bolt and clean the jet 2 holes on the side feeding the 1 from the top. If its a honda or a Chonda remove the carby and jets and clean.
Jun 30, 2010 | Garden
We have a built in Jenn Air refrigerator Model #JS48FSDBDA
Remove the kick plate at the bottom, then you will see the head of a bolt this raises and lowers the wheels, I'm assuming your wheels are up turn bolt clockwise. Thier will be a bolt on each side. The wheels are contained inside of a sheetmetal housing. Once the wheels are down you will be able to roll it back and forth. Go to www.appliancehelponline.com enter your model # and it will bring up a diagram of your unit. The diagram needed is the one for the cabinet. Hope this helps.
Mar 05, 2010 | Jenn-Air 48" Side-By-Side Built-In...
Hi, m'y dishwasher do not fully drain after is cycle, look like the installation is good and the glass filter is clean (Buyed new in june)
make sure your dishwasher was installed level side to side and front to back check it with a torpeto level (that`s a small level about a foot long ) if it`s not level there are leveling feet on all 4 corners screw them up or down to get level
Oct 08, 2009 | Frigidaire FDB1502RGC Built-in Dishwasher
Blanco dishwasher overflows at end of cycle
There is a float connected to a switch that controls water level. It is usually round and will move freely up and down by hand. But your problem might be a levelling related one. The dishwasher must be level to operate correctly. Use a torpedo level in the tank base to check front to back level and side to side level. Adjust the front legs to level the unit.
Jul 30, 2009 | Frigidaire 24 in. FDB126RB Built-in...
G e washer
remove front panel ..with putty knife press clips along edge just beneath top about 2-3 inches from outer edge front will drop off..on left side of tank will be small almost clear hose remove hose by pulling up ckd end of hose for blockage and clean as good as possible if problem still present suspect water level control ..if water continues to run in with power off suspect water inlet valve..remove screws along top edge of console and roll forward to gain acess to control and valve
Jun 18, 2008 | Washing Machines
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
