Question about Akai LCT3201AD 32 in. LCD Television
I DON'T KNOW THE DIAGRAM FOR ATTACHING THE CABLE PLUGINS
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
PLEASE place your question in the TELEVISION SECTION so that a knowledgeable person can help you.
Posted on Oct 19, 2013
An error has occurred (80010013)
If you go to recovery mode and select "disable game plugins", it should work. Alternatively you can disable plugins one by one to find which ones do/don't work. Apparently there's a good chance CWCheat is causing the problem, if you have that.
Aug 18, 2012 | Sony PlayStation Portable (PSP) Console
I still don't know why my flash player is not working and now I am missing some plugins even for this site. Why?
If you are running Firefox click the Tools menu, then Add Ons. Explore the Plugins tab to see if FlashPlayer is activated.
On Internet Explorer, open the TOOLS menu, Then Manage Complementary Modules (a loose translation of Gerer les modules complementaires ).
If you do not find the plugin, visit Adobe's site and download the player.
May 07, 2012 | Canonical Ltd. Ubuntu
I need the wiring diagram for replacing the power supply for a HP Pavilion 515n
You don't need a wiring diagram. Just pay close attention to where things are plugged in while the old power supply is still in the computer once you remove the case. There are only a few connections and some of them will only fit in the correct slot on the motherboard. For example, the main power to the motherboard will be the largest connector, then you will have a connector to the hard drive, the dvd/cd drive, etc. What you could do it take a piece of masking tape and and fine tip marking pen such as a Sharpie and write where that wire is being plugged into the motherboard. Then when you remove it and put the new power supply in, just refer to where the plugins go based on what you marked on the old plugins. There will also be some plugins that go nowhere. They are there for future expansions and upgrades that you might do.
Mar 13, 2012 | HP Computers & Internet
How to connect my dell desktop computer correctly diagram
They are all color coded. I guess you mean the speaker wires.
Jan 19, 2012 | Dell Inspiron 518 Desktop Computer
How do you get the oil pan off of a 2006 dodge stratus 2.7L
Hope this helps and please don't forget to rate!
  1. Disconnect the negative battery cable.
  2. Remove the engine oil dipstick and tube.
  3. Raise and safely support the vehicle.
  4. Drain the engine oil and remove the oil filter.
  5. Remove the structural collar.
  6. Remove the exhaust cross-under pipe.
  7. Remove the torque converter housing cover.
  8. Remove the lower bolt attaching the A/C compressor to the oil pan.
WARNING!!!!!
Be sure to remove the 2 bolts attaching the timing cover to the oil pan, as damage to the timing cover and/or oil pan may occur.
  1. Remove the oil pan attaching fasteners.
  2. Remove the oil pan and gasket.
May 08, 2011 | 2006 Dodge Stratus
I lost the manual to my craig cvd505. I am trying to set my 505 as a dvd player to watch on a old tv. It does not have video plugins. It has the older cable plugins in the back. I know I need at...
you need what's called an RF (radio frequency) modulator. it allows the standard video/audio RCA connections (yellow/red/white) to be plugged in then it routes the signals to a standard cable connection (coaxial). This cable connection carries both video and audio signal to channel 3 or 4 (selected on the modulator)._1408.jpg
Apr 06, 2011 | Audio Players & Recorders
I need the rear brake diagram on a 1988 jeep comanche
One caution on this design is to make sure the cable slide stays in the shoe, or the cable will be loose. With the slide in the shoe and the cable attached to the top post, put the return spring on to hold the slide in place before attaching the cable to the self adjuster at the bottom.
please let me know if you have any questions, and thanks for using FixYa.
Dec 21, 2010 | 1988 Jeep Comanche
Starter diagram for a 1994 dodge intrepid
3.3L Engine
  1. Disconnect the negative (-) battery cable. Raise and safely support the front of the vehicle on jackstands. Fig. 1: Disconnect the negative battery cable 88172g31.gif
  2. Remove the three bolts attaching the starter to the engine/transaxle. Fig. 2: Remove the three starter mounting bolts 88172g32.gif
    CAUTION
    Be careful when removing the starter motor mounting bolts, the motor can be quite heavy. Personal injury could result if the starter motor falls from its mounting position.
  3. Remove the starter from the the transmission housing. Position the starter to gain access to the wiring connectors.
  4. Remove the battery positive cable nut from the starter and remove the cable. Fig. 3: Remove the battery positive cable nut from the starter and remove the cable 88172g33.gif
  5. Disconnect the push on solenoid connector.
  6. Remove the starter from the vehicle. To install:
  7. Clean all wire terminals of dirt, grease or corrosion.
  8. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 90 inch lbs. (10 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  9. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  10. Lower the vehicle.
  11. Connect the negative (-) battery cable.
3.5L Engine
  2. Raise and support the vehicle.
  3. For easier servicing, do not remove the wiring from the starter motor at this time.
  4. Remove the three bolts attaching the starter to the engine. Fig. 4: Remove the three bolts attaching the starter to the engine 88172g34.gif
  5. Remove the starter solenoid assembly from the transfer housing. Position the starter to gain access to the wiring connectors.
  6. Remove the battery positive cable nut from starter and remove the cable.
  7. Disconnect the push on solenoid connector.
  8. Remove the starter from the vehicle. To install:
  9. Clean all wire terminals of dirt, grease or corrosion.
  10. Attach the electrical wire connectors and secure with the mounting nuts. Tighten the starter solenoid B+ nut to 90 inch lbs. (10 Nm) and the solenoid wire-to-starter nut to 55 inch lbs. (6 Nm).
  11. Hold the starter motor in place, then secure in place with the 3 attaching bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  12. Lower the vehicle.
  13. Connect the negative battery cable.
Oct 15, 2010 | Dodge Intrepid Cars & Trucks
Blower motor works, not pumping heat.
C, K, R & V SERIES
LESS A/C
  1. Disconnect battery ground cable.
  2. Remove glove box and door as an assembly.
  3. Disconnect the respective cable clip and disconnect the cable from door.
  4. Remove the cable retaining screw, then, while holding the cable with pliers, rotate the mounting tab on the cable to lengthen or shorten cable. Avoid pinching cable too tightly as damage to the cable will result.
  5. Reverse procedure to install.
WITH A/C
  1. Remove glove box, then loosen cable attaching screw at the selector duct assembly.
  2. Make sure the cable is installed in the bracket on the selector duct assembly, then place temperature lever in ``Cold'' position and hold while tightening cable attaching screw.
Dec 17, 2008 | 1985 Chevrolet K1500
Akai LCT3201AD 32 in. LCD Television Logo
16 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
