Question about Frigidaire Dryers
Frigidaire dryer is not blowing out hot air - Frigidaire Dryers
  • 83 Answers
SOURCE: maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
  • 52 Answers
SOURCE: dryer does not blow hot air
If this is an electric dryer, it could be the heating coil is broken or burnt through, you may have a restriction of built up lint in the vent hose, or one leg of the 220 volt breaker tripped. Please rate my solution.
Posted on Apr 21, 2009
juststinks
  • 98 Answers
SOURCE: dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
Posted on May 08, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
aasc
  • 1606 Answers
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Posted on Jul 06, 2009
I have a frigidaire FEX831CS0 that doesnt get hot while drying. Just blows cold air. Im assuming heating element...
Before you reinstall the part, have your ducts and air vents cleaned so it won't burn out again. It only costs around $150.00 but will make a huge difference in your air quality as well as heating and dryer issues.
Mar 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
1997 Frigidaire gas dryer
check the blower cage they crack then the air dosent move it gets hot and shuts off for safety and when i say gets hot only at the cage very little at dryer drum
Aug 28, 2012 | Frigidaire Dryers
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire dryer is not blowing hot air. How do I fix it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 10, 2011 | Frigidaire Dryers
My dryer frigidaire gallery GLER643AS3, built in 12/04 is no longer blowing hot air to dry my clothes. NOT DRYING!
the most common problem on these units is the heater I can help you fix this if you would like. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Dryers
Top of dryer is getting very hot
Make sure the blower is running. If you can feel air coming out the vent to the outside it is blowing. If not something could have come off the blower or it's not running.
Feb 13, 2011 | Frigidaire GLER642A Electric Dryer
Turns on & tumbles but no heat. top got really hot b4 it quit drying
You may have a clogged vent.your machine gets to hot and safety switch kicks in or you lost the blower fan
when drying does it sound like air is blowing.... let it cool down and see if it starts again
Dec 19, 2010 | Frigidaire Electric Dryer
Dryers Logo
11 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
