Question about Garden
Hi, I have a hayter spirit 41 push mower with rear roller, I've tried to remove the cutter blade, every time I put some pressure on to remove the bolt, the whole thing seems to move around, even though I am holding onto the blade, is this the friction disc moving? Just using a normal ring spanner. Thankyou. Richard.
  • 205 Answers
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Posted on Mar 21, 2009
  • 22 Answers
SOURCE: starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Posted on Mar 30, 2009
danforddan1
  • 192 Answers
SOURCE: When try to pull on the rope to start the mower is will not move. It feels like it is stuck. But I can move the blade around. Thank you
I thing the recoil spring is stuck it may be rusty. Its time for a complete maintenance on this mower. But you could try tapping the top of the recoil where the rope coils up into. Bang it a few times as you pull on the rope. this may free it up. Good luck DFD
Posted on Apr 20, 2009
  • 68 Answers
SOURCE: Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Posted on Apr 26, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
Hi I have a Hayter L324 mower there does not seem to be much power to all three cutters, thick grass will stop the blades from turning. This was not a problem last time I used the machine.
Hi Alan, it might be the nut or bolt is underneath its a disk or one big bar the thing that holds the blades to the motor, if you can spin that without the motor going that has to be tight. Cheers Greg.
Jun 11, 2016 | Garden
Which way does the bolt turn to remove the blade from a hayter harrier 41 mower
You can figure this out by checking the direction that the blade turns when it is operating and the bolt will tighten the opposite way because if it turned the same way it would loosen off when the motor was turning the blade, so almost univerdsally it will loosen clockwise and tighten counterclockwise.
Sep 19, 2014 | Garden
Hayter spirit 41
Drain tank, flush with gas. Remove float bowl from bottom of carb and clean. Fill tank with fresh gas and Stabile. Prime 3-5 times. Pull rope 10 times to start.
May 27, 2013 | Garden
How can I refit the drive belt from blade shaft to driving wheel gearbox on a Hayter R48 recycling mower?
I did it with a large screwdriver. Pressing the band with the flat end of the screwdriver pushed the drive band back under the drive wheel behind the gear mechanism at the rear of the mower.
When it was back under, manually rotating the blade made the band run free over the drive wheel
Sep 18, 2010 | Garden
Husqvarna_24hp_54_yard_tractor
when was the last time you took a look at the cutter blades,,or serviced the cutter deck? if the cutting blades are blunt or rounded off it will stall the engine stress the belts and the clutch,,,also if the mower has been standing un ran all winter it may have "rust" on the engine valves,,running the engine unloaded for a time may knock this off but under load the compreshion is pushed up into the inlet and pops back through the carb,,,try putting into the fule a little "two stroke oil" only 5cc a gall no more! this will lube the velves and carb,,,but sharpen them cutter blades up first,,,or its like trying to eat a half cooked stake with a blunt knife and no teeth? that reminds me? were have my teeth gone?
Jul 31, 2010 | Husqvarna 24HP 54" Yard Tractor ()
How do you fit a new drive balt on a hayter 41 lawnmower
dont know what the new ones are like but the old ones you had to drop thr rear roller to get enough room to put the chain back on the top cog.
Jul 29, 2009 | Garden
THE STARTER CABLE ON MY HAYTER 41 PETROL LAWNMOWER HAS JUST BROKEN. HOW DO I PLEASE REPLACE IT, OR DO I NEED TO TAKE TO A HAYTER SERVICE ENGINEER? BRIAN TAYLOR
hi,if you can remove starter housing and think you are up to replaceing cord then you can get replacement cord from any repair centre but may be as well to take starter along and they should do it for a nominal fee ,which is cheaper than if you damage it doing it yourself,it doesnt have to be a hayter dealer since the engine is a briggs and stratton ,hope this helps
Apr 07, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
