Question about John Deere EZtrak Z225 Zero-Turn Riding Mower
Very rapid clicking sound when key is turned, battery charged terminals cleaned, wont start
Won't start. plenty of juice. Won't start, even with a jump. Very rapid clicking and all dash lights strong.
The clicking sound indicates that there is insufficient charge reaching the starter motor to turn over the engine. If you have enough charge going into the starter, use a multi-meter to check, test at no load and under load. Then check your terminals on the battery and starter to ensure all are clean and tightened properly.
Jan 25, 2015 | 2003 Toyota Highlander
My Volkswagen golf won't start tried jumping it and the lights turn on but even then doesn't start but when ever I turn the key over I hear a rapid clicking sound now my guess was a starter but when we...
I suspect you have a loose or poor connection of the battery cable or ground connection or bad cables. The rapid clicking is the starter solenoid, and it clicks because it is not getting enough current from the battery to energize and turn the starter. Make certain the battery is good, and charged, clean and tighten the battery terminals, check the cables, check the connection at ground and at the starter. I hope this helps steer you to the solution.
Mar 28, 2014 | Cars & Trucks
When I turn the key to start the engine, the engine does not crank and there is a loud, rapid clicking sound. I'm certain it has to do with the starter or solenoid, but can't recall my high school...
Pop the bonnet and check your battery terminals, most likely you are not getting enough charge from your battery, if they are loose, tighten them, if this doesn't work you will need to charge your battery.
Nov 03, 2010 | 1996 Toyota Corolla
When I turn the key I get a rapide clicking sound
Check your ground wire for battery where it connects to your frame.
Also check/clean the connections where the positive wire goes to the starter solenoid. Any connection you run into from the battery, clean them off with a wire brush or sandpaper.
Starter Solenoid can also be failing/dead, these can be tested for free at most auto part stores if you remove them from the vehicle.
Jun 17, 2010 | 1998 Chevrolet C2500
Wont start funny clicking sound when i turn the key ???
Hi!!
The clicking you are hearing, is the sound of a weak battery, Jump start the vehicle and take it to an AutoZone for a Charging System check.
Good Luck!!
Mar 20, 2010 | 2006 Land Rover Range Rover Sport
Turned the key to start the car but got a rapid clicking sound
this is common this time of year with the seasons changing.The clicking is the result of low battery voltage/amps and it's the starter clicking but not turning over the motor.
It's got to be either the battery is getting old and needs to be changed or there is something preventing it from charging, OR it's dirty battery terminals.
Check the battery connections to make sure they are clean, corrosion free and snug. If they are dirty, get a battery terminal cleaning brush and clean the battery top, and terminals.. be cautious because the acid is highly corrosion and will not only burn your skin but it can eat holes in your clothes...
You can neutralize the acid/corrosion with baking soda. apply liberally and hose off with water.
If your battery is dry on top, and the connections are clean, if the battery is more than 3 years old, it's most likely going bad. Simply swap it for a new one. If the battery is newer and the connections are clean, then you may have a charging issue...
But also check to make sure you didn't leave courtesy lights on overnight... If that's the case, get a jumpstart or charge the battery.
Nov 21, 2009 | 2005 Dodge Caravan
2004 Galant won't turn over
battery may have a bad cell, change battery and check charging system
Sep 01, 2009 | 2004 Mitsubishi Galant
Won't turn over - rapid clicks - panel lights flicker
Check the battery condition - it may be flat,
check battery terminal posts are clean and connection cables are not loose or corroded.
Aug 29, 2009 | 2001 Volkswagen Jetta TDI
Truck sometimes starts and sometimes wont. i hear a clicking soun
Unbolt and clean your battery terminals if dirty or corroded, preferably replace the bolts (good auto parts stores stock them, and they take some effort to remove and replace them but it's necessary to properly clean the terminals anyway) charge, jump or replace battery ... connect battery terminals and don't over tighten ... start the truck, check charging system gauges confirm charging voltage over 12V 13.8V-14.5V and lights should be bright as normal ... if so, you may be fixed ... if not you have charging system issues, that will be the next post if needed.
May 12, 2009 | 1997 GMC Sierra
John Deere EZtrak Z225 Zero-Turn Riding Mower Logo
27 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
