Question about Avaya 4610
Call Forwarding My phone forwards all the calls to my voice mail without evenringing and I already tried several rings..any ideas?
  • claudial88 Sep 26, 2007
    My phone forwards all the calls to my voice mail without evenringing and I already tried several things..any ideas?
    **misspell corrected
Press your DND button, I suspect your phone is in Do Not Disturb mode
Posted on May 08, 2008
Check the programming of the coverage path of the station and change the number of ring you desired.
Posted on Jan 27, 2008
    Problem Solver:
  • 12 Answers
Get its software updated and for sure your problem is going to be resolved.There is nothing much you can do with IP address assigning or with the hardware.
Posted on Oct 10, 2007
Phone does not ring. calls go to voice mail. how can I change this
go to settings call settings click more setting then click call voice call. click disable on all the four always forward , etc and you should be able to receive calls
May 24, 2015 | Samsung Galaxy Note 4G
How to keep calls from going to voice mail
Remove call forwarding to the voicemail pilot extension. Either forward it to somewhere else or don't set any forwarding and it'll just keep ringing.
Jul 10, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
Toshiba dkt 2010-sd voice mail doesn't answer
To help you I would need to know what type of Toshiba main cabinet you have. If you have a CTX or CIX it may be that your system call forward is turned off. If you dial #620 at the extension in trouble it will turn the system call forward on. #621 turns it off. The proper sequence for "No Answer Call Forward" is Press ext. button + #6031 (tone) + dial main ext for voice mail + timer (08~60)
(tone) . #6051 removes this type of forwarding.
Mar 12, 2014 | Toshiba Strata DKT-2010-SD Digital Display...
Canceling call forwarding from one extention to another
On the extension that is forwarding use Feature #4 to cancel the call forwarding unless it is programmed under the capabilities section in programming. This will require someone with programming ability to make the forwarding change back to the voice mail access number.
May 01, 2013 | NorStar M7310 Corded Phone
I have a problem with my Samsung iDCS 28D phone. All incoming calls used to be routed to me by default (unless caller specifically punched in a different extension). Calls are now being routed directly to...
try dialing 600 to clear call forwarding, then re-set your forwarding to busy/ no answer followed by the VM number.
I have uploaded a 'how to' video, more of these are at
I hope this helps.
May 12, 2011 | Samsung DCS 12 Corded Phone
All calls go directly to voice mail
The phone is probably forwarded to voicemail. Leave the handset down and dial "Feature # 4". This will remove the call forwarding option. There are also automated call forwarding options -- Call Forward-No Answer, and Call Forward-Busy. CF/NA will transfer calls to voicemail after 4-rings (for instance). CF/B sends all calls to voicemail if you are on your phone. System programming, by a certified technician, is required to make changes to these options. Hope this helps.
Jul 15, 2010 | NorStar Meridian M7310 Phone
Can't activate voice mail on Mitel 5212 IP phone
You need to verify your Call rerouting, you will also need to clear any call forwarding that might be active. Its possible the system is not able to transfer a call to the forwarded location.
Sep 29, 2009 | Mitel 5212 IP Phone
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Incoming ringtone length
if you have voice mail, you can set the number of rings before forwarding to voice mail in the administrative options of the voice mail menu itself. Call your voicemail and listen for administrative options. Follow the prompts.
Mar 11, 2008 | Lands Phones
Avaya 4610 Logo
531 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
