Question about Bose Wave Radio
Bose Radio doesn't turn on
There is nothing showing in the display.
  • 7 more comments
  • Poko Nov 12, 2007
    Same problem here. Occasionally, I get random segments lit up on the display, but basically it won't turn on and none of the controls work. Most of the time it is dead with no display. Do you think it is the same component that needs to be replaced? What specific NPN transistor # do I need to replace it?
  • Wayne Dec 01, 2007
    I could not find an R402. there is an R404, but there is no transistor underneath it. My radio is an AWR1-1W.
    It's probably not related, but the backup battery never worked from day one.
    Help?
    Wayne Lehker
    Milford, OH
  • Poko Jan 02, 2008
    No, R402 is a resistor on mine. So is R404. My Bose Wave is a series I or II. The few transistors it has are D and Q numbers.
  • Poko Jan 04, 2008
    I see now....I misread the solution earlier. There is an SMD transistor "under" R402 on the backside -- it's Q401.
  • captvideo Jan 28, 2008
    The display had most if not all segments lit up all the time, but the radio would not turn on. Now, nothing works. Ive spoken to Bose with no help offered. I am an engineer and would like a schematic???
  • lynn2207 Feb 03, 2008
    Radio doesn't turn on.  The transformer is hot. Fuse looks good.
  • gianun Feb 08, 2008
    I have the same problem. The display does not light up. You can hear the speakers when you plug into the wall but nothing works???? Help!
  • Anonymous Mar 03, 2008
    mine is just dead - i don't know how to check the fuse.
  • hernandogome Aug 14, 2008
    after a puwer surge All items on display come on, but nothig works, buttons or remote, what capacitor or diode do I have to replace , I am handy with electronics [email protected]
  • 52 Answers
BWR-I, BWR-II.
Check R406 for open. It could also cause by faulty Q401, 5V supply to the display. Cold solder or fractured joints between display and main PCB.
Good Luck.
Posted on Jan 03, 2008
The problem is a shorted NPN surface mount transistor on solderside of the PCB. It is located underneath of R402.
This transistor is used to switch power to the unit.
Hap Nguyen
[email protected]
Posted on Oct 12, 2007
2 Suggested Answers
SOURCE:
BillB-SA
  • 2761 Answers
SOURCE: Bose wave radio won't turn on
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monpoly on repair of these units. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to provide a $200 allowance towards purchase of a new Wave. Before you spend the big bucks on theis trouble-prone product though, you might want to check out the new HD radios -- better sound and MUCH lower prices than Bose.
Posted on May 22, 2009
Bose radio will not turn on
You didn't mention which model of the Wave Radio you have but since you have a 9V battery it narrows it down to a couple of models. You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
May 19, 2010 | Bose Wave Radio
Bose lifestyle 38 has power but will not function at all. The display reads Bose Lifestyle - Try to turn on radio and nothing happens. Tried using remote for second zone and the remote display said no...
The sub is bad.the power supply inside the sub is your problem.If your unit comes on it could also be a defective dsp pcb in the sub.everything in the sub runs the head unit.If you send to bose they have a 175. flat rate.
Feb 12, 2010 | Bose Lifestyle 38 System
The RSX BOSE radio stopped working.
If you disconnect the bose radio, it loses it's programing.. Needs to be taken to a GM dealer and vin coded. as for the volume knob, it's digital.. if it's not working it wont be a connection issue, it's likely a flaw on the board. The best place to get that fixed is United radio in NY. 1-800-448-0944
Aug 07, 2009 | Bose Car Audio & Video
HOW TO UNLOCK RADIO 4 AUDI A6 1999
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
Mar 12, 2009 | 1999 Audi A6
Will not turn on
See if the problem is connected with the cord, then replace the cord.
Jan 07, 2009 | Bose Wave Radio
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
Bose Wave Radio Logo
905 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
