Question about Music
NEED MANUAL FOR JOY KEYBOARD TS 632 - Music
Sustain issue with Yamaha MM8
Your pedal may be the wrong polarity for this keyboard. Different manufacturers wire differently. And some use trs 1/4" and others use ts 1/4". Contact Yamaha customer service to get the correct pedal for your instrument.
Apr 08, 2016 | Yamaha MM8 MUSIC SYNTHESIZER
I have a Samick KK1 weighted controller keyboard and I can't get the sustain to work - any ideas?
I would check the input plug on your pedal. Some contollers will be wired for a 1/4" TS jack, some for a TRS jack, and you may have the wrong one.
Feb 17, 2015 | Music
Need user manual for MK-4902 midi keyboard
Use LMMS software on PC. You will need a MIDI to USB cable which you can get on eBay.
The manual can be found at:
webpages.charter.net/rochamalhada/MK-4902.pdf
Sep 20, 2012 | Music
Need an owners manual for a Casio lk-100 keyboard
you nearest casio dealer may have one in the back of the store,
many buyers don't want/need the manuals so some stores hold on to them for such occassions
Jun 28, 2012 | Casio LK-100 Keyboard
How do i plug in 2 passive speakers without having speakon cables to insert into the back?
The mixer uses unbalanced TS connectors You need these connectors to hook up the speakers. Below is a link to the manual for the mixer.
link:
Mar 09, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
I need a user manual for casio ctk 691 keyboard;casio ctk691 musical keyboard
Here is the link to the user manual
http://support.casio.com/en/manual/008/CTK691_EN.pdf
Feb 23, 2012 | Casio Ctk691 Keyboard
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Aug 31, 2008 | Yamaha Full-Size Keyboard
Music Logo
222 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
