Question about White-Westinghouse Replacement Burner Grate 3160
I have an old Westinghouse Continental Double Oven electric range. I need to replace both oven gaskets. I have not been able to locate the model number on the stove. Does anyone know where model number might be located.
How do i find the fuse location for a Wolf double oven, Model D030F/S ?
Dear Friend,
Pull the oven towards you, disconnect any electrical cord from the wall. Normally the fuse is located right next where the electrical cord enter in the back of the stove. If there is any panel right on top of where the electrical cords connects to the oven, simple removed that cover and there should be a fuse. If not, removed the rear panel where the electronic control panel is. Hope you can find it!
Good Luck!
Sep 20, 2014 | Wolf Range Ovens
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
What does code F1-2 mean
"F1:2" is a Runaway Cook Lower Oven error. This indicates that the oven temperature sensor is defective and needs replaced. The following link explains how to replace an oven sensor on most ranges:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
searspartsdirect.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
If you have any questions please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jun 24, 2010 | Maytag Gemini 30" Self-Cleaning...
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Jan 29, 2010 | Kitchen Ranges
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Jun 22, 2008 | Creda C362E Electric Kitchen Range
White-Westinghouse Replacement Burner Grate 3160 Logo
Top White-Westinghouse Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a White-Westinghouse Kitchen Range Expert? Answer questions, earn points and help others
