Question about Bauknecht Dishwashers
Bauknecht dishwasher green light flashes twice
4 Suggested Answers
  • 1550 Answers
SOURCE: Bauknecht GF7199 F7 light has come on
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Posted on Mar 06, 2009
jsrock516
  • 5911 Answers
SOURCE: Green "Clean" light keeps flashing, dishwasher won't start
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 15, 2009
Daniel S
  • 4323 Answers
SOURCE: My Bauknecht GSFK 2351 dishwasher would not start
Hi
Please check if the green light flashing 6 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry. If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Posted on Jan 03, 2011
Water left in machine, not emptying, light flashing
you may have an inefficient or partially blocked water pump remove drain hose and check if there is an obstruction if so clear it and re attach hose try draining machine listen to water flow if strong ok if not you still have an obstruction or faulty pump if no flow at all pump or control failed on final drain hope this assist you
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Hope this helps .
Mar 06, 2009 | Bauknecht Dishwashers
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
May 04, 2008 | Dishwashers
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Flashing
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 10, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Dishwashers Logo
44 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
