Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Reset button goes out very quick - Intermatic Malibu 300W Power Pack Transformer ML300RTW
CHANGE A TYRE THAT HAD A PUNCTURE HOW DO I RESET THE SENSOR
Resetting the TPS varies by manufacturer. Some have a reset button somewhere under the dash and others will reset themselves after the pressure is back within spec and a certain about of time goes by.
If you have the vehicle owners manual a quick check there should have the answer. Or the manufacturer's website.
Good luck.
Mar 13, 2015 | Cars & Trucks
Iphone stuck on apple log won't restore
Try doing a hard reset. Hold in the middle button on iPhone and the top power button.
Sep 03, 2014 | Cell Phones
When I push '-' to make image smaller screen goes black
Check your setting in "Custom Functions". Sounds like your "-" (or more specifically your "*" button) has had a feature enabled. I had my "*" button set for focusing - under Focus Settings in Customs Functions. If in doubt reset all Custom Functions to their default.
Mar 05, 2014 | Canon EOS 40D Digital Camera
Reset change oil light
To reset the system, you must do the following:
  1. With the ignition key to ON, push the RESET button located in the driver's side instrument panel fuse block.
  2. When the CHANGE OIL light starts to flash, press and hold the RESET button again. The reset is complete when you hear the chimes sound and the CHANGE OIL light goes out.
Dec 05, 2010 | 2001 Pontiac Grand Am SE
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
My ipaq does not load fully
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me.
Aug 07, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Service reset for S80 2002 2.9 liter
Press and hold the odometer reset button. Turn the key one position and pause for one second. Then turn the key once more until all the dash lights come on. Hold the button until the SRS light (picture of a guy with a air bag in front of him) goes out. As soon as it goes out release the odometer button quickly. It should be about fourteen seconds. Then turn the key off and start the car.
I can't remember if it's the 2001 or 2002 that is changed. One is like this, but the other is the triangle will flash of the "service due" light will come on. If you've tried the others I hope this will fix it.
Mar 10, 2009 | 2002 Volvo S80
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
Ipod
Whatever you do, do not disconnect it when it is like that. Do a reset (hold the menu and play buttons until the screen goes black and then quickly disconnect it from the computer.
what you do now depends on what the iPod does after you disconnect if from the computer. If the screen comes on, then you are OK. If it comes back to the do not disconnect screen, do a reset again, and this time when the screen goes black, quickly hold down the play/pause key and the middle key. Hold them until you see a check mark and the words, 'disk mode'. Connect it to your computer while it is like this and restore it. Hope that helps.
Sep 07, 2008 | Apple iPod MA446LL/A MP3 Player
Image go off
I have had the same problem. I've just managed to get the monitor working again by VERY QUICKLY navigating through the monitor setup menu to the 'factory reset' option and hitting reset before the screen had a chance to blink off.
The problem I had is that the monitor suddenly goes black, but will come on for five seconds if I switch it off and on with the power button.
In that five seconds, I had to...
>Hit the menu button
>then hit the '+; button once
>then hit the menu button again
>then hit the '-' button
>then hit the menu button one last time
The above brings up the menu, scrolls up off the top of the list to the last item on the list (Factory Reset), selects Factory Reset, selects 'All settings' and resets the monitor.
I don't know if this is a permanent fix, but it just worked for me and mine has been doing this intermittently for the last week.
Give it a try, it's frustrating and will take a few tries, but it can't hurt.
Oct 27, 2007 | Dell E173FP 17" LCD Monitor
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
12 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
