Question about Haier HMSE03WAWW (33 cu ft) Compact Refrigerator
Remove drip tray from haier HMSE03WAWW
I cannot get the drip out.
2 Suggested Answers
  • 172 Answers
SOURCE: Compressor on Haier hmse03waww mini-frige
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Posted on Sep 30, 2008
Hi, my Haier ice maker seems like there's water dripping when when the ice drops in the tray so the water that drips together with the ice freeze together and makes it difficult to use single blocks.
yes ive seen this before , it turns out that the automatic valve that lets the water in isn't shuting all the way off , something is maybe stuck inside it (no water filter on line ??) also you could just replace the valve too , that works too !!
Jan 10, 2017 | Haier Refrigerators
What is the red light that flashes and won't let it come on
Hello. Surprisingly, I had that very problem happen to me with my Haier AC this morning. The machine is telling you that your 'drip pan' is full. If the A/C kept running it would overflow the drip pan and will get the water all over your floor. Very easy solution. In the back center of your machine just above the floor is a black plug. When you pull the plug out, water will come out, so before you do so, get a shallow pan (I used a lunch tray) and put it underneath. The plug isnt threaded, just pull and twist to get it out. The amount of water that will come out is significant but doesnt come close to filling a lunch tray. Once drained just put the plug back in securely and turn on your AC and you're good to go.
Jun 19, 2014 | Haier Heating & Cooling
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
My temperture/therostat regulator isn't working. I set it to 1 and it is freezing all my drinks
That means the thermostat is bad and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Haier Refrigerators
There is a drip coming into the refrigerator from the ceiling , but the freezer is not frosted
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Nov 16, 2011 | Haier HTE18WAA Top Freezer Refrigerator
I have a Haier HMSE03WAWW Compact Refrigerator and it was running fine for about a year. All of a sudden it stopped running. I unplugged it for a day and plugged it back in and it started running. Got a...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 05, 2010 | Haier HMSE03WAWW (33 cu ft) Compact...
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
New fridge
Hi!!! sorry to inform you , but you have a seal system problem.Them haier frigs have problems with the seal system..You i\either have a restriction or a leak in the evaporator..
Jan 14, 2009 | Refrigerators
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
Mike
Sep 29, 2008 | Haier Refrigerators
Haier HMSE03WAWW (33 cu ft) Compact Refrigerator Logo
20 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
