Question about Behringer Audio Players & Recorders
My iNuke NU6000 power amp is cutting off and its not even redlining during usage and the volume LEDs are not orange around the volume knob it goes red n then no LED light at all, the fans are still running but no sound, how do i resolve this :(
SOURCE: No Light from projector (worked previously)
theres prob something wrong wif the bulb
Posted on Dec 20, 2007
marsrover
  • 682 Answers
SOURCE: sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Posted on Mar 15, 2008
Marrie
  • 563 Answers
SOURCE: Panasonic PT L501U Projector
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Posted on Apr 18, 2008
  • 319 Answers
SOURCE: ps-400 buzzing
You may have an open capacitor in power supply. Replace cap
Posted on May 10, 2008
marsrover
  • 682 Answers
SOURCE: problem with azur 640a amp
protection mode activated to protect your amp from a problem.
please disconnect all your speaker from the amp and check if it is fine start to connect your speaker one by one until you find the bad one which make the problem-change its cable first and then speaker itself.if the problem still you will have a problem in amp.
Posted on Jul 13, 2008
Inuke NU6000 keeps cutting Out
Ive had this happen with a bad ground (usually in the terminal and connection on the vehicle side). Hope that helps!!
Sep 15, 2014 | Car Audio & Video
How do i put my behringer inuke 6000 dsp in stereo mode?
Behringer iNUKE NU6000DSP
Stereo mode is set by the DSP processor ( I/O amp mode). The link above will lead you to the manual. On the main page go to "documentation" and to "manual , English". Review and study the functions of the DSP processor. Yo'll nedd to find I/O amp mode.
Jun 02, 2014 | Behringer NU6000DSP iNuke 6000-Watt Power...
Does anyone know how i should hook up a pair of peavey sp118 Bxsubs with a pair of peavey pr15 tops and the behringer inuke nu6000 please help
You will require 4 heavy gauge 1/4" speaker cables in order to connect all 4 cabinets to the Behringer power amp. Usually two longer ones from the power amp to the sub woofer cabs. Then two short ones from the second "thru" jack to the upper 15" cabs. Remember the entire audio frequency range is going to all four speakers. Sometimes you will have problems balancing the low frequency levels between all four cabs depending on the loading of each. A more desirable way to do this is with a bi-amped arrangement. This way two seprate amps are used for the subs and 15" cabs and you control them independantly.
Dec 23, 2013 | Music
Power amp goes into protect mode when turn on
Do you have a load (speakers) connected to the amp? Some amps shut down when there is no load connected?
Sep 11, 2013 | Behringer iNUKE Series 3000W Stereo Power...
Behringer inuke 3000 goes into protection mode when turn on. What is the problem?
Might be that a simple screw is loose or temp protector, but often the mute/ power off with these simple units is done with a capacitor and resistor, there would be the first thing to watch, just check which ic regulates the the power on/off mute ic
Sep 10, 2013 | Behringer iNUKE Series 3000W Stereo Power...
My amp becomes distorted when I turn my keyboard up. Both the Master Volume and the CH1 volume knobs are in the middle(12 o'clock). How do I keep my amp from distorting?
You left off the one bit of info we need... however, make sure the volume control on the keyboard is around the halfway point... If it is way down, turn it up and reduce the channel volume knob some. Make sure the cable from the keyboard is an instrument rated interconnect and not one intended for speaker (usually marked as such). Make sure the keyboard AND this amp are powered from the SAME receptacle... even if you have to run an extension cord. Listen with headphones on your keyboard to make sure the sound is clean there.
Sep 01, 2011 | Roland Elektronische Musikinstrumente...
Orange TT. cuts out on high gain on both channels, what can be the problem?
You MAY be exceeding the capability of the unit causing the thermal protect of the PA chip to shutdown. A 15 Watt amp is NOT going to make a lot of noise unless you have super-efficient speakers that are say 15 inch ones in decent cabinets. You still will be limited in sound level. Just because the gain control goes to a paticular number doesn't mean the amp can take it !!! Mpost of these use 7 terminal amp chips about the size of a TO220 transistor. Heat sinks are OFTEN very inadequate.
May 27, 2010 | Orange Amps Orange Amplifiers Tiny Terror...
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
61 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
