Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Damaged Maxtor Cable Socket
I've knocked my Maxtor off the computer desk and it landed on the cable damaging the socket on the unit itself. The PC now won't recognize the Maxtor and I get an error message stating there is a power surge. Is there any way the cable socket can be repaired? Thanks Nigel
    Novelist:
    Champion:
  • 382 Answers
NO. Its also probably the drive a suffer physical damage. Imagine a cd player being dropped as it is reading/writing, except you can change the disk. You will most likely have to ( or have a trained technician ) extract the drive, place it into a new enclosure, and test the drives stability. Hope this helps.
Posted on Oct 02, 2007
  • Keith Seekwhensir
    Keith Seekwhensir Oct 02, 2007
    NO. Its also probably the drive a suffer physical damage. Imagine a cd player being dropped as it is reading/writing, except you CANNOT change the disk. You will most likely have to ( or have a trained technician ) extract the drive, place it into a new enclosure, and test the drives stability.
    Hope this helps.
SOURCE:
The computer works fine...the screen does not show anything
that mean one of three
1- see small square in the middle of the monitor mean data cable is damaged
2- monitor led didn't light mean power cable is damaged or monitor
3- vga socket in motherboard is damged
best regards
Apr 04, 2011 | Computers & Internet
Hi, every time i connect this to my home computer it turns it off! if i turn the computer on with it already connected it turns it off, have done initial set up on work computer and can access ok from...
sounds like your pc's usb socket has a problem, try the following...
1. Try a different usb port,
2. Using a small light (and possibly a magnifying glass) look inside the usb port on the pc for bent pins or distortion within the socket causing the pins to touch something they shouldn't.
3. check the usb cable for minor damage, try a different cable if you can, different machines use different ways of manufacturing sockets making some more sensitive to a damaged plug than others.
The pc turning off is a safety system which prevents power being sent through data ports. If the pc turns off immediately after inserting the usb cable then that's a sure sign that there is a bad connection/short somewhere between the socket and the cable.
Hope this helps.
Jan 16, 2011 | Verbatim 250GB USB Portable Hard Drive
I have a nikon coolpix S 3000 which i have beeb able to download the pictures to my computer. Tried it this morning but when i plug the usb cable into the camera the screen goes black and nothing happens....
I think it is one of these: 1. the cable is kaput or 2. the socket where the cable goes into the camera is damaged (most probable) or 3. the socket where the cable goes into the computer is damaged (easy to check)
You could try cleaning all connections with a cotton earbud.
I've had this problem before - I damaged the camera socket - I've learnt to be more gentle! To get around it I bought a card reader. This is a better option anyway, as the delicate electronics of your camera are not subject to powers surges that may occur while it's connected to your computer.
Hope this helps! H
Dec 31, 2010 | Cameras
Model no. 210e/3 which when plugged in throws the trip switch . owned by Bob Earl, Earls Court, Cotham, Newark. NG23 5JS
This is a serious malfunction and is most likely caused by the compressor or fan motor being defective or a severely damaged cable.
First, with the mains plug removed from the mains socket check the plug for being loose or any damage. Take off the top cover and check that the wires are still firmly anchored to the connecting posts and the securing screws are tight. Check that there are no stray wires showing and make sure that the outer cable sheath is firmly secured by the nylon securing strap. Then check that the mains cable from the plug to the appliance has not been cut, crushed or appears to be damaged in any way or has been lying in water. Also make sure that there is no fluid leaking out of the unit.
Then try plugging the unit into a different socket to make sure that the socket itself is not defective. If this is OK then the most likely case of the problem will be a compressor or fan motor seizure. This will need a service engineer visit to rectify the problem. Contact EuroCave directly on 0207 935 4679 if you are in the UK or your nearest fridge servicing engineer.
Sep 21, 2009 | EuroCave Refrigerators
My mouse has stopped working why
what sort of mouse is it? is it a wireless/ infrared mouse (i.e., with no cable connecting it to the computer) or is it a cabled mouse?
(a) wireless or infrared? the battery inside the mouse may need replacement or the receiver unit might not be plugged into the computer correctly.
(b) cabled? the cable may be faulty or the connector that plugs into the back of the pc may be damaged or disconnected. or you may have plugged it into the wrong socket on the computer.
Jul 14, 2009 | Computers & Internet
Maxtor Basic 500Gb hard drive - knocked and will not power up?
They do not generally distribute spare parts for these cases. You can however purchase new complete enclosures without a drive for a small price and transfer your existing drive into the new enclosure. As the actual hard drive can generally survive several G's worth of drop force even when running, it's most likely the harddrive is ok. Once in the new enclosure test the drive out, if it works, you're done. If it doesn't the drive itself is the problem, reply here by adding a comment with your country and city and I will pass along a recommendation for a professional facility.
Chris
Jun 05, 2009 | Maxtor Computers & Internet
I have an LCD 1970GX monitor. I had to get a new
Your NEC 1970GX monitor as two video inputs; an old-school VGA socket (socket and cable connectors usually coloured blue), and a DVI-D digital socket (socket and connectors usually coloured white). Purchase either a new VGA-VGA cable, or if your PC has a white DVI-D socket, a DVI-DVI cable, both relatively cheap options and test this simple option before any further troubleshooting. Many computers and monitors will go to sleep (automatically switch off) after not being used after an adjustable period of time. If this is your problem, you will need to adjust the setting (in power options of both the monitor and PC) to a setting suitable to your usage. You can also, in power options, usually turn off "automatic sleep".
Oct 08, 2017 | NEC Computers & Internet
Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Dec 03, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
3000t download music from computer
1- check that you install teh driver for it 2- chekc the usb cable 3- may be teh socket of usb is damaged
Aug 09, 2007 | Magellan RoadMate 3000T GPS Receiver
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
109 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
