Question about Tally Matrix T2280 Printer
Wrong board error message lipi 2280+ - Tally Matrix T2280 Printer
Problem with head cable
head cable may be cut
Posted on Jan 17, 2014
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
LIPI 2265 printer showing hardware alram 0578
with out having all the numbers from your error code on the screen (most needed is the number ini the lower left) it is impossible to decode or decide what is wrong with your printer. more info is required. do not replace your logic board or your print cables. (rookie)
Oct 22, 2013 | TallyGenicom 2265+ Matrix Printer
Faulty Hammer voltage-2 earr
There is most likely a fault with one of the hammer coils, this would need investigating, other possible causes;Faulty / damaged ribbon cableFaulty main boardUpdate firmware, the error should change to a more meaningful error with later firmware
Dec 16, 2011 | Tally 6306 Matrix Printer
My printer Lipi 2280+ printing properly with 15*12 and fanfold 8.5*12 paper,but when i am using paper width slighly smaller than it less than 8.5 width printer gives paper with error>kindly suggest
You see the "Paper Width Error" on the 2280+ because the print job being recived by the pritner is wider than the physical paper which will cause the pritner to print on the platten, in order to rectify the problem.
  1. Ensure the print job on the system is less than 8.5 inches wider
  2. Perhaps move the paper in the tractors to the right
  3. Disabling the Paper Width Sensor will clear the error but may cause the printer to print on the Platten which may reduce print head life, the Paper Width Sensor can be disabled in the following way;
    Start with the printer Powered OFF
    Hold Down the ONLINE button and power the printer ON keep ONLINE held down until you see ASCII80 ASCII136 on the top line of the display
    Press the button under NEXT repeatedly until you see APW on the top line of the display
    Press the button under APW
    Set APW = OFF
    This will disable the APW sensor and you will not see the Paper Width Error
Dec 08, 2010 | TallyGenicom 2280 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
My lipi T6454 IS GIVING BLACK ONE CHECKSUM ERROR
I think the error you are getting is caused by corrupt firmware or damaged memory on the main board.
As a first step I would recommend reloading the firmware, this will rectify the problem if it is related to corrupt firmware.
You may need to change the logic board if the problem persist.
Feb 04, 2010 | Tally Line Matrix T6100 Printer
Tally 2280 printer givesw printhead hot error
Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
Feb 14, 2009 | TallyGenicom 2280 Matrix Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Showing hammer voltage 2 error
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
Apr 05, 2008 | Tally T6218 Matrix Printer
Tally Matrix T2280 Printer Logo
87 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
