Question about O2 Xda Orbit Smartphone
Cant answer calls
Hi I have had an orbit for a month and am loving it...except that sometimes it will ring but when I try and press a button (hard key or screen button) it will not answer the call it lock up until the call either ends or goes to voicemail! This is VERY frustrating and all o2 can offer is to send it away for two weeks to look at it! I Any ideas greatfully recieved
  • hawaiijulia Sep 29, 2007
    I took out the sd card removed the co pilot software and tried using the phone. It worked fine and answered all the calls. I have reinstalled the co pilot software using the sd card and will try again to see if it works. HAs anyone heard of this problem before is it a software conflict or corruption?
  • 76 Answers
I would try to do a hard reset on the phone. (in the settings, it will be under clear storage)
Posted on Sep 27, 2007
I have a Motorola aur12000 Cordless Phone and it does not ring loud.
Hi debora maisonave!
To modify the volume level on your phone please follow this steps:
To raise the volume:
  • During a call: press the key up to raise the volume of the call.
  • When the phone is ringing: Press the key up to raise the volume of the ringtone.
To lower the volume:
  • During a call: Press the key down to lower the volume of the call.
  • When the phone is ringing: press the key down to lower the volume of the ringtone.
Hope these steps help!
Motorola Customer Care.
Feb 11, 2015 | Motorola Mobility Dect60 Cordless W...
How do i change the number of rings before it goes to answering machine. We would like 5 rings instead of 3. Also sometimes when people call in it says our system is not set up yet.
Make sure the answering system is ON.
Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
Press key [9] to enter Ring to Answer menu on handset.
Use the CALLER ID-VOLUME (up/down-arrow) button to choose 5 rings.
You can download the manual here.
Feb 06, 2011 | GE 25942GE2 Cordless Phone System
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
My n79 stops working after a few seconds when i turn it on and some times it shuts off and restarts, and the keys wont work only the on/off. it will charge the battery and still except calls but i cant...
your keypad is in good condition? cause sometimes the keypad is still in press. if is not try format your phone but first back-up your files. when format press * key, call key and 3 key and power key. always update your phone to the latest firmware.
*#0000# to check the firmware
Jul 11, 2010 | Nokia N79 Cellular Phone
LG Vu answer buttons is broken
This won't fix the broken button, but there is another alternative. Press the main menu button, then the last button on the bottom right (settings), then "Call". From there you should be able change your "Answer Mode" from Send Key Only to Any Key.
Apr 15, 2009 | LG Vu Cellular Phone
Cannot hard reset XDA orbit - Forgot password
To perform a hard reset
1.Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom center part of your device.
2.Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: "Press SEND to restore factory default, press END to quit."
3.Press on your device.
On my XDA the reset button is located on the left bottom side of the XDA.
Apr 02, 2009 | O2 Xda Orbit Smartphone
Answer machine
Sometimes there is a switch, sometimes it's a key combination. What's the model number and I can look it up?
Mar 24, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
How can i hard reset my o2 xda orbit?coz i 4get ma password..
To do a hard reset.
Press both soft keys and insert stylus into soft reset button and press.
Release the soft reset button and keep pressing the soft keys.
When the "This operation will delete all your personal data, to manufacturer default" appears on screen.
Press Green call button to restore manufacturer default, or press other keys to cancel.
more helpful information about your device:
Let me know if you need anything else.
Mar 07, 2009 | O2 Xda Orbit Smartphone
Software needed
may be key pad problems, have your phone serviced at authorised service centers
Sep 16, 2008 | Sony Ericsson K790i Cellular Phone
NEC DTU 16D-2 issue
hi, adjust the ring tone volume. from your phone set,press speaker dial the arrow key up or down to adjust. 2. if your station is programmed as system admin phone,then you can press feature 80 toggle between day or not press speaker button while doing this. 3.the headset port need to be program,or you can do without it,by purchasing the headset came with the adapter and connect thru the handset cord. the new model is DTH-16D. CAN email me if you need a new phone,
Sep 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
O2 Xda Orbit Smartphone Logo
48 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
