Question about Kyocera Office Equipment & Supplies
Malfunction detected error code c-0204 in konica minolta c350
  • 214 Answers
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Posted on Dec 07, 2007
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
Posted on Aug 30, 2008
  • 15 Answers
SOURCE: malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
Posted on Jun 09, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
C450 c-0204
Pull out the cassette and check the paper capacity not to exceed the maximium level. Clear any irregular or untidy paper if any.
Feb 24, 2014 | Konica Minolta Office Equipment & Supplies
C 0060 c350
Please there is no such code in Konica minolta please check again for the error code maybe you mistype it.
Jan 24, 2014 | Konica Minolta Office Equipment & Supplies
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Oct 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Aug 28, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Copier malfunction
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
67 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
