Question about GE Televison & Video
Murphy 26883 tv works fine,remote stopped working.changed the batteries and still nothing!.HELP
  • 1694 Answers
SOURCE: Pregramming my RCA Gemstar Video Plus remote with no codesearch button!
www.remotecodelist.com ........................................T.
Posted on Mar 22, 2008
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Posted on Nov 28, 2009
SOURCE: alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Posted on Feb 22, 2010
Testimonial: "Excellent! It works, many thanks for your help"
  • 1335 Answers
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Posted on Feb 03, 2011
SOURCE: My remote has just stopped working on my Bush
Hold down the menu button whilst pointing at the tv for 15 seconds an it will re-configure itself. It worked for me. Cheers Nick
Posted on Feb 25, 2011
My LG AKB73375501 has stopped interfacing with my Blu Ray player but interfaces with my TV. I can only control my Blu Ray player via my TV remote. How do I get my LG AKB73375501 to interface with my
with lg this is normal and there is nothing you can do beside to take the set in for a exchange or repair service- I have an lg device or two that has the same issue, it is the players not the remotes. if i find a solution i will update you good luck questions just ask
Mar 30, 2013 | LG ELECTRONICS Remote Control AKB73375501...
Samsung txd1372 remote commands doubled or tripled
Murphy's law says that the tv only does what it is told. No flashes on it's own? Check the remote battery's first easiest.
Then open the remote to see if these is dirt or dust in the keypad.
If some liquid got in there clean with solvent on a rag. Don't put the solvent on anything else.
Wipe off the sending unit on the front of the remote with damp rag.
If this does nothing then blame the tv or get another remote to try out.
Mar 03, 2013 | Samsung TXD1372 13" TV
Murphy C1999Fipod remote control numbers
Hi All,
I have a Murphy C1999FIPOD Combi TV/DVD with no remote control, so I bought a one-for-all control from Asda, but all codes listed do not work - can anyone help please????
Jan 02, 2012 | Televison & Video
Akai KC02-E1 Remote with new batteries stopped working.
First, You cannot resync the remote, Second the IR sensor may be bad on the tv and third, the Digital bd may be bad. The IR sensor connects directly to the Digital bd which is the brains of the tv. Also, there maybe a stuck button on the remote or the buttons on the tv.
Jul 13, 2009 | Akai PT4298HD Rear Projection Television
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
Remote won't work
hi, see if the right funtion is selected, tv, vcr, dvd.then if that does not help, get a universal remote. they don't cost alot or some don't good luck. hope this helps.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I need hardware (screws) information to assemble a table top tv stand for an ILO LCDTV model LCT32HA36
Dear Mr.
I have read your requirements. Let me know first which type of SCREW you want kindly description of that . I can supply the same as per your specifications.
Thanking you,
For Reliable Repair
K. Kumar
reliable_repair@yahoo.co.in
Apr 10, 2008 | Televison & Video
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Televison & Video Logo
32 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
