Question about Hotpoint Washing Machines
HV7L130 SOFTENER PROBLEM - Hotpoint Washing Machines
Bypassing softener when watering the lawn. Uses too much salt..can we turn off the water softener when we are watering the lawn and how do we do this.
leave the setting on the water softener alone as it will become a tiresome exercise
place a "t" joiner in the water line before the softener with a tap on the outlet side to the softener and a tap on the outlet side to the lawn hose and fix your lawn hose to that
That way when you want to water the lawn adjust the taps so that the water softener is cut off and the hose is turned on
or when using the softener the tap is turned on and the hose is turned off
use ball valves ( 90 degree action)with a handle and the direction of the handle will determine the direction of water flow
Jun 19, 2016 | Dishwashers
Fabric softener is still in dispenser after wash
Check for clogged water nozzles in the dispenser. Also, it's advisable to check for a gummed up softener dispenser--softener has a nasty habit of drying out and leaving a thick waxy paste on everything. Check the dispenser where you put in the softener--I recommend CUTTING THE SOFTENER 50/50 WITH HOT WATER to keep it very fluid. Softener causes lint! Be a scrooge when it comes to adding softener--enough to make the clothes smell nice and be soft--BUT THAT'S IT!! On rare occasions, one of the electric inlet water valves might be malfunctioning and not letting water flow to the softener dispenser.
NOTE TO EVERYONE!!!==>ON ALL *HE* WASHERS, NO MORE THAN 2 TABLESPOONS OF LIQUID DETERGENT IN ANY LOAD, IT'S PLENTY!! You're only using 1/3 of the water the old style washers used to use. As for softener, use only enough to get the job done--and always cut it with hot water, especially in the winter.
Aug 19, 2015 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
Softener WG 844 needs flushing to remove dirt
If there is DIRT/SEDIMENT coming through system then you have a bigger problem. Well problems! Bypass the softener and run water into white bucket to see if it is coming from well. If so keep unit bypassed and call well man. The call Culligan to rebed softener.
RJ
Mar 23, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Fabric softener doesnot seem to work
Open soap drawer and remove little 'hat' from it's post in the fabric softener compartment. Make sure both are clean and free of softener residue.
Mar 18, 2010 | Washing Machines
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric softener compartment blocked
The fabric softener section in the drawer on my washing must be blocked as the fabric softener is staying in the drawer. Does anyone know any way to unblock it
May 01, 2009 | Bosch Washing Machines
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Feb 14, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
