Question about Tomtom GO 930 GPS Receiver
WERE DO I GET A TOM TOM 4CS01 CHARGER IN DURBAN?
TomTom 4CS01 white screen, solution please!
backlight on the screen has probably failed and needs to be replace or it has simply unclipped from its socket on the motherboard
Mar 04, 2013 | Tomtom GO 930 GPS Receiver
Tom tom will not switch on when i try to charge it the led light does not come on i have hardly used my tom tom
What is your charging method? In car or house hold plug? Suggest that charger is not working (Green) if light on Tom Tom (at bottom near charger lead) is not lighting. Check your charger and see if you have an indicator light on it showing it is on. If yes, plug in Tom, then press and hold the "on" button for 15 seconds constinuously. Tom Tom should reboot.
May 01, 2011 | GPS
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
Tomtom only charges on fast charger base. Why?
if it is not charging in the car then the socket in the car is dead, blown fuse or defective socket..
Aug 09, 2009 | Tomtom GO 920 GPS Receiver
My tom tom one won't charge because the charging unit on the base of tom tom has lost the part that connects to the charger, do I have to buy a new one?
She charges on USB with a PC. If USB port suplies power, not all do.
Seperate home charger for sale.
Or replace original.
I hope you talk apot that cable to cigarette lighter.
Mind you I have a Go 300
Apr 15, 2009 | Tomtom ONE XL GPS
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Tomtom GO 930 GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
