Infotec 5222z error E-1 - Office Equipment & Supplies
2 Suggested Answers
  • 1297 Answers
SOURCE: Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Posted on Aug 14, 2009
Testimonial: "a very helpful expert, thanks copydoki"
Error code sc320 showing on infotec 4151mf
That is a polygon motor error.
This motor is from the Laser Unit. Probably you have to change it.
If you do not have technical training i advise you to call your provider.
Mar 11, 2011 | Ricoh Aficio 250 Copier
Error code sc202 on infotec isc615g
SC202 is a problem with what is called the polygon motor, It is the motor in the laser unit and has most likely failed.
Jul 14, 2010 | Ricoh Aficio MP 161SPF Color Copier
Infotec 5221dz when machine starts up it all
Check the sorter and exit part gears.Remove the sorter unit and make a copy.If the machine worked the problem is in the sorter unit,if not workwd the problem in the exit unit.If the sorter is defected you need to de-reassambly the unit,checked the mechanical components,sensors,motors and gears,and realignament the bin sections.For more information and suggestion please contact me.
Oct 10, 2009 | Ricoh Office Equipment & Supplies
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
Aug 14, 2009 | Ricoh Office Equipment & Supplies
The copier warms up and comes up with an error code of sc173
please precise which is the brand and model
by the code it seems to be a ricoh,nashuatec,lanier,infotec,rex-rotary,gestetner
but you have to specify the model
Mar 19, 2009 | Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
SC551 error on Infotec IS2220D same as aficio 2020D
it must be a small damage in capacitors in power supply
Mar 25, 2008 | Ricoh Aficio 2020D Copier
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
12 people viewed this question
k24674
jasbo
jasbo
