Question about Dell 1410X Projector
Temp warning light - Dell 1410X Projector
Signs bad temp sensor
Bad oil pressure sensor, oil pump, balancer-shaft bearings..
Which grade of oil did you use? Did you try to check the pressure with an oil-pressure gauge?
Sep 14, 2017 | Saab Cars & Trucks
Where is the engine temp gauge on 2013 chevy spark?
There is a symbol on the right side instrument cluster, but probnably just an overheat warning symbol......We are all waiting for the Haynes manual to be published, Haynes told me will be out in March sometime.
starman2236
Feb 22, 2013 | 2012 Chevrolet Spark
Warning light to the left above temp light, red and yellow snow flakes yellow in colour, no audio warning, not flashing, 2007 ford mondeo
It is an outside temperature warning light. Turns yellow when the temperature gets to around 5 degrees and then turns red with the temperature gets to around 0.
Mar 06, 2011 | Ford Focus Cars & Trucks
Red warning light marked A/T Temp has come on.Meaning?
This light warns you if the transmission temperature goes to high
Jun 29, 2009 | Mitsubishi Raider Cars & Trucks
My yamaha fz6 shows hi temp & engine warning light
Need to check the ECU for registered malfunction.You must take it to a dealer's workshop.Engine warning light means that a sensor is not working properly.
May 27, 2009 | 2005 Yamaha FZ6
Light
From left to right
1. The wrench light is the service interval light.It will illuminate after about 4800 miles or 358 days to remind you your vehicle is due for service.To reset hold the SELECT and UNITS buttons on the trip computer for 5 secs. The light will illuminate then extinguish itself after about 4 secs.
2. Frost warning light. This light illuminates yellow when exterior temps are between 39 to 32 deg. F to warn you of possible icing on the roads.It will illuminate red if temps drop below 32 Deg.
3. Brake pad warning. Will illuminate when brake pads have worn down to the sensors in the pads.
4. Washer fluid warning.
5. Door Ad-jar
6. Bulb failure. Indicates an exterior bulb is out.This will illuminate until brake pedal is pressed after starting engine unless of course one of the brake lamp bulbs is burnt out.
Feb 26, 2009 | 1999 Mercury Cougar
On the interior roof warning lights there are two lights that keep coming on(orange and red) that look like snow flakes. What sre these warning lights for?
These are outside temp. warning lights. The Yellow light goes on when the outside temp. dips to 40 degrees to let you know that there is a possibility of frost. The Red light goes on when outside temp. dips to 30 degrees suggesting a possibility of icy conditions.
Feb 21, 2009 | 1999 Mercury Cougar
Can you email me a picture of what the dashboard warning light look like when the windshield wiper fluid is low on a 1993 mercedes 190e? I don't have a manual and need to know what this signal means....
Hope you can make it out on the Pic
From the right to the left.
H/beam lights on
Charge Light
Brake pad low warning light
Hand brake/ brake fluid low light
Engine oil low light
Engine coolant level low
(space for outside temp display, yours might not have this)
Wind screen washer fluid low
ABS warning light (your might not have this)
Exhaust temp warning light (only if the vehicle is fitted with CAT"s)
Dec 04, 2008 | 1993 Mercedes-Benz 190
Yellow warning light
Dunno where you reside but our indoor/outdoor digital thermometer shows a snowflake once the temp drops down to 0C/32F. It wouldn't surprise me to learn that a Jag would have a warning light for freezing temps.
Nov 16, 2008 | 2003 Jaguar S-Type
Dell 1410X Projector Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
