Question about Master Lock 5400d: Portable Select Access Key Storage Lock
How to reset master Pro Series 1174 padlock - Master Lock 5400d: Portable Select Access Key Storage Lock
What's my combination
Each padlock has a different combination. If you lost yours, that's reall bad luck. Take it to a good locksmith, maybe he can find out. If pretends to charge you too much, get a new padlock
Apr 12, 2015 | Master Lock 175D Combination Padlock...
On menu there is a lock for a choice and is not going to auto scan
At master TV remote Hard Reset button available. Use master remote to reset your TV or from option menu try to restore setting.
Oct 04, 2014 | Element Televison & Video
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
Master code for brinks padlock
the lock combination is not working anymore, I can not open the lock, how I can reset the new combination
Sep 04, 2012 | Brinks 1-1/2 In. Brass Combination...
How do i reset my administrator password? its for a MacBook Air
You have to have your original administrator password for this. To change the administrator,
  1. Open the Settings application.
  2. Click the icon that says Accounts.
  3. Make sure the icon that looks like a padlock (bottom left) is in the unlock position, if it is not: Click it and enter the Administrator username and password.
  4. Go to the user you want to make administrator, and check the box that says Allow User to Administer This Computer
  5. If you want to remove the previous administrator, you go to his user and uncheck that box.
  6. Click the padlock to save.
  7. Done!
Apr 30, 2011 | Apple MacBook Pro with 17" Display
CARRIER AIRCONDITIONING HEATING/COOLING
Need to check the condensor fan. If the fan quit working this could lock out the unit so the compressor does not over heat.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I forgot the master combo and now i cant get it...can i reset it?
I don't know if Master Lock will supply a combination or not but they can open it for you. There might be ownership issues that need verified. They don't know who's keys are in it and they don't know if the lock has been stolen.
Aug 23, 2009 | Master Lock 5400d: Portable Select Access...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
153 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
