Question about Kenmore 19233 Computerized Sewing Machine
E9 error code kenmore sewing machine - Kenmore 19233 Computerized Sewing Machine
2 Suggested Answers
Tally Girl
  • 1133 Answers
SOURCE: kenmore sewing machine won't sew vinyl
There is several things you should use when stitching vinyl, treat it the same as leather. The main issue usually is getting the feed dogs to grip and move it through; this is why there are commercial grade machines specifically for leather hides and fur etc, it is tricky to stitch.
To stitch on a domestic machine, you need a leather needle with a spear tip to cut the leather so it doesn't split. Also, if you can get one, use a roller foot to roll over the fabric, or a teflon foot if you can't find a roller one. Also, use paper clips rather than pins to hold raw edges together (remove as they approach the foot and needle). You may also need to bash seams open after stitching (rubber mallet) and glue down the raw edges, this is how leather hides are stitched professionally. If you have to join more than 2 layers ie crossing seams, you'll probably need a Jeans-a-ma-jig device to help with feeding through the thickness and still getting feed. Like this http://www.punchwithjudy.com.au/shop/jean-a-ma-jig.html
You don't say what it is actually doing, ie stitches not catching, or the feed dogs not moving it through?
But if it is an entry level machine, it may not have sufficient engine power to pierce the vinyl, especially if the textile is thick. Also, don't try to use a heavier thread than normal weight, if you want the stitching to look heavier, then just run two reels of thread through all the thread guides, tension and the needle eye together. Something like buttonhole twist will be too heavy for the bobbin tension and top tension to handle.
Hope that this helps you with your project.
Posted on Dec 18, 2011
Kenmore 385.19233 shows E1 and I can not find it in the manual. What does it mean It is a sewing machine
I have found that most often the E1 code means the presser foot is not down or not all the way down (a walking foot attachment can keep it from dropping all the way). I didn't find any error codes in the Kenmore manual either. I have several Brother machines that are quite similar in design and since Kenmore doesn't actually make anything, it is probably made by Brother or Janome.
Feb 03, 2017 | Kenmore Sewing Machines
Will not sew making noise, have cleaned and checked bobbin holder displays E9 I also cleaned feed dogs
Difficult to say since we don't know the make & model.
Usually, you can search the internet for:
Make + Model + error code E9
and sometimes it will tell you what the error means.
Aug 21, 2016 | Sewing Machines
My kenmore 19001 has an error #1 what does this mean
Usually the manual will list common error codes under the troubleshooting section. You can probably also contact Kenmore Support.
Apr 28, 2016 | Kenmore Sewing Machines
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
Feb 14, 2016 | Sewing Machines
Fix for Janome error E9
take it to a repair shop the computer control is faulty
Apr 19, 2015 | Janome Sewing Machines
My machine shows an error number E1what is it
The error code 1 indicates the fuse on the A board has blown. The fuse should be replaced with a part number 000182177 fuse. The original fuse is a 2.5 amp fuse and the replacement fuse is 3.15 amps.
You should take the sewing machine to a Sears service center or a retail store for repair.
Sep 11, 2012 | Kenmore Sewing Machines
ER message on Kenmore Sensor Sew 70
the halifax switch under the top cover needs to be adjusted
Nov 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
