Adobe update Adobe Flash Professional CS5.5 Update 11.5.1 There was an error installing this update. Please quit and try again later. Error Code: U44M1P216 I have a user that is trying to fix a bug where when he's worked on this application it only saves parts of work. The guy uses CS5.5 and when running this update it fails and gives the above message.
SOURCE: Can't get Adobe Flash Player 9 ActiveX.exe to download.
First uninstall http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe
Then it finally worked for me
Posted on Mar 29, 2008
worldvet
  • 859 Answers
SOURCE: Windows fails to start and startup repair does not work.
Your startup repair option in Windows Install indicates a hardware conflict. Go to your System Setup in startup mode, by pressing Del, F2 or F10 whichever the hint is on screen during bootup. Once inside system setup, turn off almost everything, disable Speed Stepping in EPower, set monitor off to disable, Standby and Hibernation off as well. Turn off the modem and Network adapter if yo can. Just about everything that affects a device on the laptop. This would also include the Touch Pad if you're using a mouse.
And, in the long run, you may need to do a full Windows Install if the repair option continues to fail. Many of these failures are due to the Virtual Memory file size for Drive C being too low. If you can get into Safe Mode change this setting, right click My Computer, select Properties, go to Advanced, advance and change Virtual Memory on C to a fixed size about 1024Meg for min and max.
Also, should you be low on free space for drive C this could cause the same problem. You would have to choose a Full Install as an Option unfortunately.
In the absence of anything along these lines working, you should be able to choose Restore Acer option (or words to this affect), you would want to tap on F8 while booting, sometimes its F10, but this gives you a 'boot from what source' option, CDROM, Hard Drive or Restore Partition. Choose the Restore Partition and start over from scratch again.
Sorry, but this often happens and you and I have to live with this.
If you need any clarifications on what I've just stated, use the Comment Box Text Entry box below to send me a message. I'll get an email alert and will get back to you as soon as I can.
Regards,
Worldvet
Posted on Nov 08, 2008
  • 5 Answers
SOURCE: Chrome Adobe Error
Fresh out of Google suppot -
"Download the flash player for windows xpi file - http://fpdownload.macromedia.com/get/flashplayer/xpi/current/flashplayer-win.xpi
"Rename the file to .zip
"Explore the .zip file and you will see a couple files, flashplayer.xpt and NPSWF32.dll, which you have to copy.
"Open another explorer window and go to the plugins folder of your google chrome browser, which might be at -
C/Documents and settings//Local Settings/Application Data/Google/Chrome/Application/Plugins/
"Paste both the files in this plugins folder and then close your Chrome browser and restart it
Those instructions worked fine for me, but I had to make one small change to the advice given there - Vista uses a different folder structure, so I had to paste the two necessary files into C:\Users\{Username}\AppData\Local\Google\Chrome\Application\Plugins
The folder Plugins did not exist when I navigated my way there, so I created it and dropped the two files in, restarted the Chrome browser and ... Voila! Working fine
Other thing I’d say is that my first step was to visit the Chrome Help pages, in particular, http://www.google.com/support/chrome/bin/answer.py?answer=95697&cbid=1798iqe1e7223&src=cb&lev=answer
and installed Java 6 v 10 like they suggested, before doing the Flash business
Posted on Nov 27, 2008
Vivektj
  • 55 Answers
SOURCE: Having trouble installing Adobe flash player.
There are a couple of steps you will need to do to install flash
1. Uninstall any old or already installed version of flash on the computer. http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe You can also run this if you don’t have flash or are not sure.
2. Restart the computer
3. Download the stand alone installer from http://fpdownload.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_10_active_x.exe and save it to the computer desktop
4. CLOSE Internet Explorer if is open (IMPORTANT)
5. Install the downloaded file install_flash_player_10_active_x.exe from the desktop.
Flash should not be working
Posted on Mar 02, 2009
TechiFriend
  • 11 Answers
SOURCE: "Error applying transforms. Verify that the specified transform
Run kb404307.exe on affected systems. Important: You should be logged in as an Administrator in order to use this tool.
  1. Download the kb404307.exe utility from the Adobe website.
  2. Double-click kb404307.exe to run it.
Posted on May 17, 2009
Stop message
Check for updates or just update adoe flash player
Adobe Flash Player allows users to view videos made with Flash, a common online video format that can be viewed by both Mac and PC users.
Because technology is consistently emerging, Adobe frequently updates its Flash player. Downloading an update is free, and may be required in order to watch videos online.
You will need at least 128 MB of RAM available on your computer to update Flash player, and Internet Explorer version 6.0 or later for Windows XP, version 7.0 or later for Windows Vista and Internet Explorer 8.0 or later for Windows 7.
Open Internet Explorer and navigate to Adobe's Flash player download site.
Click the download link and follow the instructions on your screen.
Click "Allow" or "Install" if your security system asks if you want to download the file.
Avoid running other programs while the download is going on.
Flash player tests itself by showing you a brief video when the download is complete.
If you do not see this video, the player has not been successfully installed and you must try the download again.
http://get.adobe.com/flashplayer/
or you might try
http://adobe-flash-player-non-ie.soft32.com/
11.4.402.278Free
Adobe Flash Player is a cross-platform browser-based application runtime.
Jan 11, 2014 | Computers & Internet
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
I can not play certain apps signing in with my fb it tells me error line 2
That means there is an error on line 2 on the code for the program, have you tried updating your adobe flash player and built in java?
You can update adobe flash by going here:
http://www.adobe.com/products/flashplayer.html
You can update java by going here:
http://www.java.com/en/download/index.jsp
I hope this fixes your problem friend :)
Feb 26, 2013 | Computers & Internet
Script error
With the 0.8.0 Update, Adobe Flash must be installed independently on your computer for the launcher to successfully launch the game. Download Flash here: http://get.adobe.com/flashplayer/
This should minimize script errors in the launcher. If you guys have any further issues please send us a support ticket.
Installing the IE variant (which probably should be linked to explicitly instead of the general "get it" page) sorted out those script errors on Launcher.exe
It did not resolve the issues with the One-Click Application Reference launcher, of which I have been trying to fix it in a support ticket.
Nov 01, 2012 | Dell Computers & Internet
Type error 1009
This problem can be fixed by editing script code.
I would suggest to un-install the browser.
  • Clear all registry entries by using registry cleaner like Reginout
  • Restart PC
  • Install the latest version of browser
  • Update the flash player
Hope the problem is fixed.
Jun 18, 2012 | Adobe Systems Adobe Flash Player
I am having trouble trying to install Adobe Flash even after doing all of the usual suggestions. Any Help?
What kind of trouble are you having? Are you getting any error/missing file error messages? What version of Adobe are you using and/or are you trying to update Adobe when you are getting these error messages?
Jul 09, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Adobe flashplayer download error
  • Reset your browser, Delete cookies and temps and close your browser.
  • Open the Brower like Internet Explorer, Mozilla, etx..
  • Click to Download flash player unistaller( if flash player or plugins installed)
  • Close the browser again and reopen it
  • Download the latest flash player from this link.http://get.adobe.com/flashplayer/?promoid=DXLUJ
  • Install and Restart the browser again.
Hope this Helps, Please Rate My Response! Thanks!
Prem
Feb 19, 2009 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
David Payne
David Payne
