Question about Fortinet Computers & Internet
Activation error - Fortinet Computers & Internet
How do I reach this special page to ?get the activation code on.
Windows activation or validation fails and may generate ...
https://support.microsoft.com/en-us/kb/921471
Microsoft CorporationDiscusses that activation or validation fails and generates error code ... Level: Error Description: Acquisition of Secure Processor Certificate failed. ... To do this, follow these steps for your version of the operating system. ... Volume Activation error codes on Windows Vista-based computers ... Get help with activation errors
Standalone Product Activation FAQs - SOLIDWORKS
https://www.solidworks.com/sw/.../1090_ENU_HTML.htm
SolidWorksWhat does SOLIDWORKS do with the computer-specific information sent during the ...Does product activation make the software harder to use? ... number which is then down sampled to reduce the size of the activation request code. .... name, version, and language; and your computer's processor and hard-disk type.
Activation Keys and Serial Numbers
georeference.org/doc/activation_keys_and_serial_numbers.htm
Jan 09, 2016 | Computers & Internet
Tip
PSP ERROR CODE "8010850f"
How to fix error code "8010850f" on your PSP:
Error code "8010850f" sometimes appeared when you downloaded certain games on your PSP. It will requires you to activate the system to use the content and could only work when activated through PSN. Here are some tips and tricks on how to fix this error.
Option 1: Go to account management by signing in to PSN on your PSP. Once under account management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to [Accountmanagement] - [activate/deactivate] - [PSP] - [games].
After you processed either of the 2 options you can now play your games with no interruption.
Hope it helps.
on Feb 21, 2011 | Video Game Consoles & Games
Why is it showing error code 90?
Sounds like a all the bells and whistles thermostat, why did you chose that one?
090 Data interface is continuously busy.
A log of error codes can be viewed at the end of the installer setup after the system tests. Active errors will be shown first. The Error Log will log the last ten errors (active and inactive).
Pressing the reset button will clear all inactive errors from the
error log; active errors can not be cleared until the condition has been remedially busy
Dec 27, 2015 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Error 20 for activation 3d max 2010
registration activation error 0015 111 after
registration activation error 0015 111 after installing revit architecture 2013 on window 8 pls help urgently
Dec 14, 2013 | Autodesk 3ds Max 2010 for PC
I am getting error code 0x80070005, how do i fix this
Windows Activation Error : Error Code 0x80070005 I have upgraded my x64 Vista to x64 Windows7. After adding to companies domain, it asked to activate windows again. but its giving the following error when i try to activate it : "Windows Activation Error : Error Code 0x80070005"
The link for the fix is described at the Microsoft Website, link listed below.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/windows-activation-error-error-code-0x80070005/90fb852d-a507-4c76-a672-0be2ecbdb320
Sep 30, 2013 | Toshiba Computers & Internet
I am having trouble with Microsoft Office Home and Student 2007
This article describes how to troubleshoot problems that you may experience when you try to activate a 2007 Microsoft Office application. Additionally, this article contains several methods that you can use to troubleshoot activation issues.
This article is intended for a beginning to intermediate computer user.
You may experience the problems in the following scenarios:
Scenario 1
When you try to activate a Microsoft 2007 Office suite, you may experience one of the following symptoms:
  • You receive the following error message:Your software cannot be activated because the product key you installed with is not valid. Please uninstall the software and reinstall it using a valid product key.
  • The activation process fails. Additionally, you receive a message that states that you have reached the limit on the number of computers on which you can activate the 2007 Office suite.
Scenario 2
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, you receive an error message. The error message indicates that significant changes were made to the configuration of the computer. In addition to this error message, you may also experience any of the following symptoms:
  • When you try to activate the 2007 Office suite, the Activation Wizard disappears.
  • When you try to to activate the 2007 Office suite over the Internet, you receive a communications-related error.
  • When you try to activate a 2007 Office suite , the Activation Wizard does not start. Additionally, you receive no error messages.
Scenario 3
You try to activate the 2007 Office suite over the phone. However, after you enter the confirmation ID that the support staff supplied to you, you receive an error message. The error message states that the confirmation ID is invalid.
Scenario 4
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, the 2007 Office application now runs in a reduced functionality mode.
Scenario 5
When you start a 2007 Office Trial version for the first time after you complete License Activation, the 2007 Office Trial version runs in a reduced functionality mode, and the Office Activation Wizard is displayed. Additionally, the following text is displayed:
2007 Office system is expired. In this expired state, many features of the version are unavailable until you convert to the full product. Click Convert to begin the conversion process.
Note This activation problem indicates that the Opa12.dat file is corrupt for the 2007 Office application. Scenario 6
When you try to obtain an activation key for a trial version of the 2007 Microsoft Office system over the Internet, you receive the following error message:The Microsoft Activation Assistant was unable to request your trial activation key
This issue is temporary until the updated version of Try Microsoft Office 2007 is available. Microsoft is in the process of updating Try Microsoft Office 2007 based on the January 2010 update for Office Word. For more information, click the following article number to view the article in the Microsoft Knowledge Base:978951 Description of the January 2010 update for Office Word
Oct 26, 2011 | Microsoft Office Home and Student 2007...
Psp error code 8010850f when trying to play demo games
From TIPS section:
Hope it helps.
Jun 18, 2011 | Sony PSP (Piano Black)
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
InDesign Activation Error Code 194:3
I, RAJNISH JAGOTA has been successful in installing the Adobe CS3 but it does not recognize the activation code and shows error message 194:3. Pl provide solution
Apr 01, 2010 | Adobe InDesign® CS3 5 Upgrade Version for...
I can't activate photoshop cs2 in my pc
Did you followed the right way to activate it?
if its cracked version then activation is done staying ofline, using phone activation code
Sep 08, 2009 | Adobe Photoshop CS2 for PC
Computers & Internet Logo
Top Fortinet Computers & Internet Experts
David Payne
David Payne
Are you a Fortinet Computer and Internet Expert? Answer questions, earn points and help others
