Question about GPS
Where is the reset button on copreci control box
I want to delete the parental control and have no code number please help many thanks
  1. Open the Parental Locking Settings screen (MENU - SETTINGS - PARENTAL LOCKING). Press OK.
  2. You will be prompted to enter your PIN.
  3. Use the ARROW buttons on your remote control to select TURN OFF LOCKING, and then press the OK button.
  4. Select RESET ALL PARENTAL LOCKS, and then press OK.
  5. Select RESET ALL PARENTAL CONTROLS. Press OK. A message appears asking if you want to reset the 4 digit PIN and stop using parental locks.
  6. Select RESET and press OK.
The set-top box closes the Parental Locking Settings screen and returns to the last channel tuned.
The Parental locking option in the SETTINGS screen shows parental locking as completely turned off (no lock icon in the Parental Controls box).
Apr 04, 2018 | The Video Game Consoles & Games
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Pilot flame curves upward missing thermcoupler copreci style 1 in gas logs by Desa Int, can I fix?
pilot is blocked needs cleaning orfice is blocked try blowing pilot with can of air , when off , or tube and just blow .
Jan 06, 2011 | Desa International CCL3924PTA 24" LP Gas...
I have a dish network echostar remote control (20.0 IR). When I press any button that normally controls the satellite box, nothing happens except the green "sat" button on the top left lights...
Unplug the satelite box and replug it back like about an hour later.By letting the box resetting and upgrading it softwares the remote should work again now.
Dec 25, 2010 | DISH Network IR Remote Control
I have the Trio Outdoor Lightshow Tree from Gemmy. It worked great until we had to replace the batteries in the remote. I have tried to reset both the box and the remote, but no luck.
push the reset botton on the box in the tree, on the back if the remote there is a reset bottom, push the reset botton on the tree until the light start to blick then push the reset botton on the remote, thats what i did to mine
Dec 02, 2009 | Gemmy Inflatable Polar Bear on Motorcycle
I have a 2003 HR Endeavor with 2 roof ubits. The front unit will cool and heat but the rear unit will not come on. The thermostat will not cycle to zone 2. Any suggestions?
Try resetting the thermostat. If you have the 5 button comfort control, turn the thermostat off. While holding down the mode and zone buttons, turn the tstat back on and hold the buttons until FF appears in the display. Release the buttons and then see if zone 2 is available. If not, remove the inner cover off the front air and remove the cover off the control box. Inside this box there are DIP switches (red stripe with white switches). Set the one for zone 2 to off and then reset the tstat as described above. Turn zone 2 back on and once again reset. If this does not work, you more than likely have a bad control board in the front unit as this is the one that controls all that.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Stability System Reset Button on a 2003 Cadilac CTS
YOU HAVE TO HOLD THE TRACTION CONTROL BUTTON IN THE GLOVE BOX DOWN FOR 7SEC. YOU'LL THEN SEE A MESSAGE SAYING THE STABILITY SYSTEM IS OFF. IF YOU ACCIDENTALLY LET GO BEFORE IT SAYS IT'S OFF, YOU HAVE TO PUSH THE BUTTON AGAIN, AND START OVER.
Jan 17, 2009 | 2003 Cadillac CTS
It is not responding
This is one of the best solution to do, look for unit who have same model as your unit( to your friends or neighbors) and test your remote control. If it wont work in another unit with same model then the remote control is defective, but if it works then its the receiver.
But try this solution first, if there is a reset button in your remote try to reset it then try the remote to your unit.
Note: sample only(reset button can be found either infront or at back of the remote control inside the battery compartment.)
Nov 27, 2007 | Heating & Cooling
GPS Logo
16 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
