Question about Coleman Digital Compass 2000001936
Aug 28, 2016 | Brother Sewing Machines
Nov 26, 2015 | Cars & Trucks
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Apr 13, 2011 | Shimano 105 ST-5600
Oct 19, 2010 | 2001 Volkswagen Passat
Jun 05, 2010 | Panasonic CT-27SL14 27" TV
Jun 03, 2010 | Televison & Video
Dec 16, 2009 | 1995 Isuzu Rodeo
Jun 24, 2008 | Xerox DocuColor 3535 Copier
71 people viewed this question
