Question about Garden
I have a worx wg101e trimmer and I need to get a new spool and spool cover and the spool cover is the one with brass eyelets but I understand there are two types of spool for this trimmer does any one know what I need to buy
SOURCE: grasshogXP string trimmer GH1000-ca type 2 7.2 amps
You can order replacement parts from:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/CST2000_TYPE_1
Posted on Jul 14, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
How do you remove the Worx trimmer spool assembly ?
get this!
http://www.manualslib.com/manual/770460/Worx-Wg255.html
Jul 03, 2016 | Garden
My string keeps breaking causing me to refeed the string thru the eyelet.
Are you using thick enough cord for the machine?
Are the eyelets worn and have sharp edges.?
Is it being threaded correctly?
May 22, 2016 | Worx 24-volt Cordless Electric Lithium-ion...
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
I have a Worx trimmer/edger and I have 2 problems with it. The battery doesn't last long enough to trim/ edge my yard. Normally I have to charge the battery 3 times or more just to trim my property...
Well your battery problem is quite simple. Litium batteries have a life and as the cells deplete, they will not hold as much charge as they once did. The part number for your unit is Worx WA3512.1 and can be purchased for about $53.00. As far as the spool retainer clip is concerned, you will be looking for a hard to find part. Here is the good news, you can purchase a brand new WORX GT WG150.1, which is the model you currently have, for only $95.00 on Amazon. I hope this helps you and let me know if I can be of additional assistance.
Jun 20, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
thanks...
Charlie
May 29, 2009 | Worx GT WG150 10 in. 18 Volt Cordless...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
